Not able to unlock achievements
Welby
I'm trying to do an achievements system as simplest as could be. I just need the easiest way to unlock a specific simple achievement.
I setup 15 achievements in the Oculus dashboard,I'm using the Oculus platform SDK and Unity 2017.3.1p4 and my code looks like that:
void Start () {
        Oculus.Platform.Core.Initialize();
            if (Input.GetKeyDown(KeyCode.F2))
            Oculus.Platform.Achievements.Unlock("Collector");
Something that simple.. I have an achievement called Collector on the dashboard obviusly. What Am I missing? What should I add to make it working? I'm finding the documentation really confusing and it mostly cover only Progressive achievements and not simple ones.
@imperativity
Thanks,
Andrea
1 ACCEPTED SOLUTION
Accepted Solutions
Welby
Alright sorry to multipost but at the end I figured this out. It works and achievements.unlock is just enough. I noticed they were resulting as unlocked in the notifications. Would be cool something to show in-game though.
3 REPLIES 3
Welby
Alright so at end I did something like previusly posted and i was able to check if the DLC was unlocked or not with the following code:
public void CheckForAchievmentUpdates()
        Achievements.GetProgressByName(new string[] { FinalString }).OnComplete(
            (Message<AchievementProgressList> msg) =>
                foreach (var achievement in msg.Data)
                    if (achievement.Name == FinalString)
                        Debug.Log(achievement.Name + " :"+ achievement.IsUnlocked);
However I'm not sure  Oculus.Platform.Achievements.Unlock("Collector"); is enough to completely unlock the achievement or there's something else i should call to make sure the acheivement is unlocked and saved as such.
Welby
Welby
Ok everything works as expected. They are also shows in-game. You need to make a build to see them in the editor obviusly aren't visible.
Silly me
