1) I can't seem to mute the microphone ovr_Voip_SetMicrophoneMuted doesn't seem to do anything. No matter what I pass, ovr_Voip_GetSystemVoipMicrophoneMuted always returns VoipMuteState.Unmuted. If I mute the microphone using dash, I still get a result of VoipMuteState.Unmuted.
2) Setting the microphone filter callback doesn't seem to work calling either ovr_Voip_SetMicrophoneFilterCallback or ovr_Voip_SetMicrophoneFilterCallbackWithFixedSizeBuffer with a callback function - my callback function never gets hit.
I've checked that the microphone is outputting sound via windows sound settings, but I don't see an option to check microphone output in Oculus settings.
Hi Imperativity, thanks for the reply! - I switched tasks over to Achievements and Leaderboards for the past couple of days, so I'll need to gather some more info for you, however:
I only have one game project right now - I'll try again with the samples and let you know.
I haven't upgraded to 2018.2, however, is the SDK integration different for 2018.2 (i.e. the newest integration for platform services I see is 1.28)? The upgrade from 2017.4 to 2018 is substantial, and I'd like to not introduce more risk at this point into the project if I don't have to. That being said, I'll give it a shot and let you know.
Hi, an update now that I'm back on working on VOIP support for our game - I was able to get VOIP working fine using the sample code in my current version of Unity (2017.4.1f1) - the only thing that I can see that I'm doing differently in my game is that after the VOIP connection is started, there is a scene change - I found that if I test for audio immedately after VOIP connection is established and before the scene change I can hear audio in both headsets - but after the scene change occurs audio stops playing (I'm still getting OnAudioFilterRead callbacks from the engine audiosource component, but the data received from ovr_Voip_GetPCMFloat is always an array of floats that are 0).
OK - I found it - it was a problem with game data - there was some uninitialized data that was being read in after the level is loaded which was being used to mute the microphone on the player. Because of course.
Thanks for the help imperativity - going back into the samples let me find a couple of other things as well!
