Unnecessary permission RECORD_AUDIO in Platform SDK for Unity
UmairEm
Recently my app got rejected with note:
Your app is asking for excessive user permissions or using user permissions inappropriately.
Here are all the permissions appearing in build info:
android.permission.READ_EXTERNAL_STORAGE
android.permission.INTERNET
android.permission.WAKE_LOCK
android.permission.ACCESS_NETWORK_STATE
android.permission.RECORD_AUDIO
android.permission.WRITE_EXTERNAL_STORAGE
At this point, RECORD_AUDIO permission is not required but its included because of MicrophoneInput.cs script under OculusPlatform/Scripts. If I remove this file and related files which use Unity's Microphone class and build the app, RECORD_AUDIO permission is gone. It makes sense to include this file in a project which actually uses Microphone at some point. But I am never gonna need it. Shall I remove this file and related files (IMicrophone.cs, MicrophoneInputNative.cs)? Are there any other files in Platform SDK which should be removed to avoid bugs due to code dependency?
Please advice me how to fix this
Thanks
20 REPLIES 20
Fulby
Level 7
I removed the microphone cs files (maybe a voip one too) and don't remember any problems regarding dependencies.
Truthveyor
I'm using Oculus Platform SDK 1.20.0.  I had the same problem, and I removed the following files from the Oculus Platform SDK:
OculusPlatform\Scripts\IMicrophone.cs
OculusPlatform\Scripts\LivestreamingMicrophoneStatus.cs
OculusPlatform\Scripts\MicrophoneInput.cs
OculusPlatform\Scripts\MicrophoneInputNative.cs
Then I got errors from OculusPlatform\Scripts\CAPI.cs for missing LivestreamingMicrophoneStatus, so I commented out references to
LivestreamingMicrophoneStatus in CAPI.cs.  There are no more errors, everything worked fine, and the "record audio permission" went away.
AnneLanting
Hi there,
Is this still the proper way to do this?
Greet, Anne.
m4lumm
I am wondering the same thing. My Android app is asking for permission to record audio. I can remove the files no problem, however that is a messy solution.
seatedmech
I'm struggling with this at the moment. So in the three months since the last person posted in this thread, I take it there hasn't been any non-messy solution?
seatedmech
I did this as well, but my app is still requesting to use the microphone upon installation.
Truthveyor
seatedmech, notice I was using Oculus Platform SDK 1.20.0.  If you use a different version of Oculus Platform SDK, there may be other files requesting the use of the microphone.
I am guessing that you should look for any file with the word "microphone" in the file name and see if they were causing the problem.  In fact, I would suspect any audio related files in your project you didn't write yourself.
Nyro
I am also having this problem.
cmdr2
Along with the files mentioned earlier in this thread, I had to delete the 'Oculus/VoiceMod/Scripts/Helpers/OVRMicInput.cs' and 'Oculus/LipSync/Scripts/OVRLipSyncMicInput.cs' files as well for the RECORD_AUDIO permission to stop showing up.
I do wish there was a more robust way to manage this.
