Oculus Developer Hub: My Device > Apps > APK is not installed - nothing happens
vr_alexander
Dear community,
I am working with an APK developed by a developer in our team. In the Oculus Developer Hub application on Windows 10,  I select the Quest 2 under My Device, select Apps and "Upload" in the field "Upload an APK", select the APK (as described in Deploy Build on Headset | Oculus Developers) and then the following modal is shown for about 5 seconds:
After a few seconds, the modal disappears and the list of applications stays empty, even after 30 minutes:
The computer is connected to the Quest 2 with the USB-C cable and the Quest 2 is turned on.
Please let me know how I could install the APK on the Quest!
Thanks in advance!
Anonymous
Not applicable
Encountered the same issue today. Any luck solving it?
TomerBrio
Same happened to me. - I am using the latest Oculus developer hub.
APKs that I could upload yesterday suddenly cant be uploaded.
I got the same behavior as you describe...
I can't test my apps and APK's.
Please help !!
