02-21-2019 12:16 PM
Solved! Go to Solution.
02-25-2019 12:05 PM
02-25-2019 12:05 PM
02-25-2019 03:17 PM
Patty_Mick said:
I've watch 4 or 5 videos on youtube that said that the s10 and s10 plus will work on the same Gear VR.
02-25-2019 05:21 PM
02-25-2019 05:22 PM
02-25-2019 10:37 PM
Patty_Mick said:
Not a problem. I'm getting my s 10 plus next month. I can't wait!!!!
02-28-2019 07:10 AM
02-28-2019 09:45 AM
dpluigi said:
I'm wondering is the change in VR image quality with S10 and S10+. Reports indicated that the Gear VR16/9 format means the per eye redolresol will be the same as with S9.
What im most curious about is if the more powerful CPU and GPU willwallow improved frame rate above 60fps and cooler phone ( especially with S10+ cooling vap chamber) when comparing with previous S9?
Anyone find more details?I used VR app fine on S9 but the phone heats up too much for AR sessions and throttle down and/or need to shutdown after about 1h. I used ALVR for VR streaming and although 60fps is fine, 72 and 90fps are considered much better to help with VR sickness and overall VR experience. For AR, I can stream with ALVR-ARCore, which allows 6DOF motion in room scale environment - but is very demanding on phone CPU and it heats up.
Thanks for your inputs
04-10-2019 02:20 PM
08-22-2022 06:39 AM
Bonjour je suis un peu déçue gear vr maintenant ça marche plus avec samsung s10. Avant 2021 ça marche . Je ne me comprends pas ça ne marche plus casque gear vr2 avec contrôleur et samsung s10.
Je ne veux pas acheter le nouveau casque. Je ne trouve pas regalage....
Bien cordialement
Valerie
