Gear VR 2016 SM-R323 Specs
rgang50
I am having a lot of difficulty finding the specs for Gear VR viewer SM-R323. Specifically I looking for: Screen to lens distance, Inter lens distance, Tray/case (Top & Bottom) to lens distance, Field of View angles (Outer, Inner, Top & Bottom). I do not wish to go by tape measure (too crude).
I seek this info to define the viewer to apps such as Cardboard to get a better viewing experience. At present I am in the default mode which gets me by.
I hope this info is not "protected info" requiring "Non Disclosure" certs.
Any help is appreciated.
1 ACCEPTED SOLUTION
Accepted Solutions
NEO2016
here are the specs:
Optical Lens: Φ42, FOV 101º, x6.25
Interpupillary Distance: 62mm (fixed)
Eye Relief: 10mm
PUI / Button: Touchpad, Back button, Home button, Volume button
Sensor: Gyro / Accel. (Sampling Rate : 1KHz), Proximity
Phone Connection: USB Type-C & Micro USB
Strap: Soft band type
Weight: 345g (312g without Font Cover)
Headset Size: 207.8(W) x 122.5(L) x 98.6(H)mm
Color: Blue Black
3 REPLIES 3
NEO2016
here are the specs:
Eye Relief: 10mm
Color: Blue Black
Reverend_Brown
I don't think measuring it up yourself is too crude at all.  At the very least it would give you a good starting point, and then you could refine things using a calibration app like this: https://play.google.com/store/apps/details?id=com.anrael.vrcc&hl=en
In fact even if you could obtain measurements with sub-millimetre precision you'd still have some tweaking to do before things were optimal for your own IPD and the manner in which you wear the headset.
rgang50
Thank you both Neo2016 and Colonel_Izzi. The Gear VR does not have IPD adjustment but for my first dip in VR pool the calibration app and the specs will get me started.
Much obliged.
