How to hide bluetooth mouse cursor?
majin_vegeta117
Hi!
I'm working on a Gear VR app in Unity3D that is using a bluetooth mouse as input device to play Shadow Fight 3 Mod. Unfortunately, as soon as you move the mouse, the 2D android mouse cursor comes up, which is doing nothing good in VR, of course. Is there any way to hide it? (No, "Cursor.visible = false" does not work on Android.)
Best Regards,
8 REPLIES 8
rokcysam
same issue. Is there any way to solve this to play
Regards,
Rocky Sam
Elenasukra
kindly also help me to solve my issue to related this
LeoWebster
why are you need this?
thomadrosika
It was a complicated session, I got this error and it was annoying, you can also download good games at https://androidrub.com/games, the hottest game store today.
MODAPK
In any case
MODAPK
open world games effectively on your iPad or iPhone helpfully.
www.rexdls.com/
ghostusa
this is an easy step to hide the live tv mouse cursor if you don't get it to check here
zezba9000
This requires Pointer-Capture which will hide cursor. I've added support for this in the Unity Asset Store.
https://assetstore.unity.com/packages/tools/input-management/mobile-input-capture-221017
