Getting Notifications while using Gear VR was set to off as default, in one of the later Android or Oculus updates which is good as notifications tend to brake the performance a bit. But there is one disadvantage, that you dont get any notice when you are running low on battery until your phone eventually dies and shuts down.
Which is a bit annoying and is actually not that good for the battery life span aswell draining it to 0%, therefore it would be nice to get atleast a notice when you reach 5% of battery, even tho notifications have been switched off, hopefully that is possible.
