DOOM 3 BFG - VR ( V0.021 Updated 3-12-2017)
Samson
Level 7
Latest Release And Downloads:
Latest Version: V0.021
https://github.com/KozGit/DOOM-3-BFG-VR/releases
Updates from v0.20:
Edit: Many many thanks to 2EyeGuy for all his hard work on the .020 release, and for handling bugfixes and compiling this release while I was on vacation
Additions:
QuakeCon style teleport. ( jkchng )
Fixes from v 0.020
Fix issue #107: use other hand for movement.
Fix issue #97: Fix talking waking monsters.
Fix issues 100 & 106: Change language detection to use sound files. Issue #100 and Issue #106
Fix issues #113 and #27: Fix timing issues.
Improve issue #27:Disable ASW and make it a menu.
Improve issue #103:    Fix loading old savegames with different scripts.
Fix crash loading 020 save games, and allow old versions.
Loading RBDoom savegames works now.
"Fix" loading script objects of different sizes.
Fix save and load menus.
Adjust installer, Readme, and other docs for v 0.21 Alpha.
Work Around Movement Popping.
**EDIT:**
Known issue: After saving a game it might appear greyed out in the load game list and be unable to find it. To fix this issue, either use this console command before opening the load game menu, or exit the program and restart it:
testSavegameEnumerate
This issue is fixed in the next version.
Previous Release:
Doom 3 BFG VR: Fully Possessed V0.020 Alpha
This is sizeable update with many new features and improvements.
New features include:
Teleportation is now supported, including a parabolic aiming beam.
Voice commands are supported - say a weapon name to select it!
Flicksync mode based on Ready Player One.
Many aids to prevent motion sickness, including a new Third Person movement mode.
Many other improvements have been made, please see the readme.txt for a full feature list and documentation.
https://github.com/KozGit/DOOM-3-BFG-VR/blob/master/README.txt
Default Configuration
No single controller configuration or comfort setting is going to accommodate all users equally,
so Doom 3 BFGVR: Fully Possessed defaults to a comfort oriented mode.
In the default mode, comfort ( or snap ) turning is enabled by default,
and artificial movement uses the Third Person mode. These settings
should provide a comfortable experience for almost all users. These
settings may be easily changed or disabed in game if they do not suit
your needs. From the System Menu ( say 'System', or press ≡ (menu) on
the left Touch or Right Vive ), then select 'VR Options' then 'Comfort +
Safety Protocols'. From this menu, use the 'Turning' options to change
the turning mode (' smooth 'is standard analog turning - caution -
smooth turning causes motion sickness in most people ). Use the 'Motion
Sickness Aid' options to change the comfort settings. 'None' disables
all motion aids, but this will induce motion sickness in the vast
majority of people.
Default Controller Layout
The default controller layout can also easily be changed in game. Any
controller button or Stick/Pad axis can be mapped to any in game action,
to easily create a controller layout tailored to your liking. From the
System Menu ( say 'System', or press ≡ (menu) on the left Touch or
Right Vive ), Select 'Controls' then 'Key Bindings', Scroll through
the list and highlight the action you would like to change the control
for. Press the trigger to enter 'bind' mode, then simply press the
controller button or stick/pad axis you would like to assign to that
action. If the button or stick is already assigned to a different
control, you will be asked if you are sure you want to re map, otherwise
you are done! A button or joystick/pad axis can be unbound from an
action the exact same way.
Installing Doom 3 BFG: Fully Possessed.
There are two options for installing the mod: A self-extracting installer, or a .zip file.
Due to the inclusion of new player AAS files needed to support teleportation, the size of the mod has
increased a fair amount. You will need about 1GB of free hard drive space to install the mod.
Installing with the self-extracting installer
Download the file 'Doom3BFGVR_Fully_Possessed_Alpha020_Installer.exe' from the release page at the top of this post and execute.
By default, the installer will look to install the mod in the default
app directory in your Steam library on drive C. If your Steam library is
in a different location, or you have installed doom 3 someplace else,
browse to the location of your Doom 3 BFG installation. IMPORTANT
If you browse to select a directory to install the mod, the installer
will append 'Doom 3 BFG edition' to the install path. REMOVE THIS from
the install path, so that only the full name of your Doom 3 BFG
directory is displayed. Failure to do this will result in the mod files
being installed in the wrong directory. Once installed, you should see
a folder named 'Fully Possessed' inside your main Doom 3 directory
along with some support files and the Doom3BFGVR.exe. Launch this .exe
to play.
Installing with the .zip file
Download the 'Doom3BFGVR_Fully_Possessed_Alpha020.zip' file from the release page at the top of this post, and
extract into your main Doom 3 BFG directory. You should see a folder
named 'Fully Possessed' inside your main Doom 3 directory along with
some support files and the Doom3BFGVR.exe. Launch this .exe to play.
Compatibility with existing Mods or Native Doom 3 BFG
Doom 3 BFG: Fully Possessed stores all changed assets and save games in
their own directories. Installing the mod will not interfere with
existing mods or the native game.
Compatibility with the Hi-Def texture pack
Doom 3 BFG:Fully Possessed is compatible with the hi-def texture pack.
Please be aware that the 'generated' folder included in the hi-def
texture pack is corrupt, and will crash the game if not deleted. This
is not an issue with this mod, but with the texture pack itself. After
installing the texture pack, delete the 'generated' folder inside the
'Base' directory.
NOTES
  1. The texture pack also installs German language files. If you do not
    want the game menus to be in German, delete the 'german.lang' file in
    the 'Base/Strings' directory.
  2. It does not matter if you install the mod first or the texture pack
    first, but be aware that games saved without the texture pack installed
    will not work once the pack is installed, and vice versa.
Reporting Bugs
Many bugs have been addressed in this relase, but if you do find one,
please open an issue on our tracker. We can't fix it if we don't know
its broken!
https://github.com/KozGit/DOOM-3-BFG-VR/issues
Enjoy!
OLD UPDATES:
Update 12-10-2016
Fixed bug related to save game crashes. Archives updated
Additional Update 12-9:
I've updated the OpenVR version of the mod to address  issues some people were having, and added a few new features.
There are now versions of the mod that support OpenVR and the Rift/Touch natively via the Oculus SDK.
See  below for a link and additional info.
Update 12-9
I've updated the mod and posted a test verison with native Oculus/Touch support.
This includes full motion controls and the ability to interact with in game guis and the PDA by using them as touch screens.
Release:
https://github.com/KozGit/DOOM3-BFG-RIFT/releases/tag/v0.11-alpha
Please
make a clean copy of your doom 3 directory before installing, right now
this mod will not co-exist with other mods as too many of the
assets have been changed.
Take a look at the description on the release page, and the two readme files
included in the archive.  I've also included a .pdf that lists
most of the common cvars you can use to configure the mod.  Please
remember all the controls ( all joystick axes and buttons) can be
unbound or remapped to any other control. In the system menus go to
(Settings->Controls->Key Bindings)
There's still a little oddness during loading screens.  Let me know if you find any issues. This is the first test of this, so there may be issues I'm unaware of, please let me know if you find anything.
Previous update:
I've been working on a mod for Doom 3 BFG edition for a while, and it might be ready for an alpha test. I'm looking for people to test and let me know what issues ( and I'm sure there will be some ) you have. ( Please note this is an entirely new mod, not a variant of an existing one.)
Anyway, here we go:
New features:
Full motion control support for weapons, with support for right or left handed control.
Reload mechanics and motion controlled melee attacks are NOT finished yet, but in progress.
For now press the attack button to punch and reload to well, reload. Grenades are now
thrown via motion controls.
Flashlight modes
The flashlight can be held in the off hand, mounted to the weapon, mounted to the player helmet, or
mounted to the player body. If 'mount to weapon' mode is enabled, and a weapon without a barrel is
selected (e.g. grenade, fists, chainsaw) the flashlight is temporarily moved to the head.
Player body view modes:
You can chose to view the entire player body with ( very very basic ) IK for the arms, view the weapon and
hands, or view the weapons only.
Weapon sight modes:
Chose from a laser sight, laser dot, circle dot, or crosshair.
Optional heading indicator.
With independent head/body movement it's easy to forget which way the body ( and forward
movement) is pointing. The heading beam points in the direction the body is moving. Beam can be
solid, have arrows, or scrolling arrow. Temporary artwork.
Movement options:
The player body is locked to user position, so moving in the real world moves the player body.
Optional comfort turning, with user defined delta and repeat delay.
Walk speed adjustment from game default consistent over level changes
Option for forward movement to be in direction off hand controller is pointed
Headkick and knockback are disabled by default but can be toggled.
For non motion controls, you can lock the view and aim together, or use independent aiming with user
defined deadzones
Hud options:
Hud is translucent and projected into world.
Hud can be locked to the view or the body.
Hud position and size are configurable.
Hud can be toggled on or off, or faded in when user looks down past defined angle
If hidden, can be configured to reveal when health below defined level
Individual Hud elements can be turned on or off if desired
Stat Watch ( for the love of god someone come up with a better name )
Ammo stats are provided on a wrist worn armament inventory device if player has weapon equipped.
Soon to provide health stats as well.
Gui interaction modes.
Player can choose one of three ways to interact with in game guis
1) Look direction controls gui cursor
2) Weapon aim controls guis, in the event weapon has no barrel (grenade, fists, etc) default to look
direction
3) If motion controls are enabled, guis can be touch activated. When close enough to touch, look at gui
to activate then touch gui to control.
PDA is rendered as model in game.
PDA can be held in hand, or fixed in a position in front of the player body. If gui touch mode is enabled, the
PDA works as a touch screen device. Pressing escape during the game brings up the system menus in
game on the PDA.
PDA fixed position can be adjusted.
Cinematics
Cinematics are now from a fixed camera position. This is still being worked on, but is much better than the
free camera IMO. Some camera files still need to be tweaked for some of the cinematics. Pressing the PDA
button will exit the current cinematic
Pixel density can be adjusted.
ALL controller buttons and axes can be re-mapped to any control or action.
Weapon models have been fully fleshed out.
All of the options are currently controlled via cvars that start with vr_.  I'll add the options to the menus at some point.
The code has not been tested on any machines other than mine, so hopefully it will at least run for some of you 🙂
There are some issues I do know about. The loading and saving transitions are pretty glitchy, which is annoying.  I'll either smooth them out or just black them out.  I changed how the player hand animations work, so occasionally the hands don't play the correct firing animation.  I know how to address just need to implement.  The weapons also jump/blink for a frame when you change weapons, I know how to address I just need to get to it. Also, the source code is a mess, it's not actually on github at the moment, I'm working to clean it up and get it posted soon.
Anyway, let me know how it works for you!
908 REPLIES 908
Syndroid
Level 7
It crashes on startup for me.  Here is the error message.
0(108) : error C1008: undefined variable "rpShadowMatrices"
0(109) : error C1008: undefined variable "rpShadowMatrices"
0(110) : error C1008: undefined variable "rpShadowMatrices"
0(111) : error C1008: undefined variable "rpShadowMatrices"
0(138) : error C1008: undefined variable "rpJitterTexOffset"
0(139) : error C1008: undefined variable "PI"
0(143) : error C1008: undefined variable "rpJitterTexScale"
------- Game Map Shutdown ------------------------------------------------********************ERROR: While linking GLSL program 12 with vertexShader interactionSM and fragmentShader interactionSM
Samson
Level 7
What gfx card are you using? Also, did you install on a completely clean BFG installation?  If you put this on top of the other mod, it will probably conflict.
Syndroid
Level 7
gtx 970.
Just tried it again on another installation and now it seems to work. I'll be back with some impressions soon. 🙂
Maxxgold
Level 8
Just an FYI; if you need a copy of Doom 3 BFG, you can get a Steam key for 5 or 6 dollars on eBay.
Inateck USB 3.0 https://www.amazon.com/gp/product/B00FPIMJEW/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Valve Index Frunk Fan 3D Mod!
https://www.thingiverse.com/thing:4012790
Syndroid
Level 7
I've just tested a bit and messed a little with the console commands. There are a lot of options to customize the playstyle, that's amazing! Performance is great as well.
Only real issue I had so far is the scale.
Is there a way to change the worldscale? With the default settting the world looks too big to me, though, the weapons feel right...
"vr_scale" does not seem to work. Only way I was able to change the scale was by using the IPD override and set it to a ridiciously high value. but that messes with the positional tracking and also makes the gun/hands too small.
Would love to be able to change the worldscale and gunscale independently
For the guns I used "g_gunscale" in other versions, but that doesn't seem to work in this one
Samson
Level 7
Gunscale and vrscale are disabled at the moment.  Just out of curiosity, what did you set the IPD to?
You may want try changing the player height (pm_normalviewheight)  and then reset the orientation to see if that makes a difference. Just out of curiosity, are you using a rift or vive?  Some of those cvars are old cruft, I need to clean them out sorry.  I can look into scaling options.
Syndroid
Level 7
I'm using a Rift... With IPD set to ~75 the scale of the world looks right to me (except human npcs)
edit: 71 looks better
64 (default) feels off somehow. especially when I stand in front of things like desks or computers. same with smaller objects like cans etc.
Thane_
Level 7
Keep in mind that FOV, or the 2D size of things also plays a part the perceived size/distance of things. In 3D guns often look far too big while the world looks fine because they are given their own 2D size in the viewport. This is one area where Tridef succeeded over Nvidia 3D Vision, because it was able to specifically modify the guns 3D values independent of the world. I don't know if thats the issue as i can't try it, but i just wanted to throw that out there.
This mod looks great! Can't wait to try this when i eventually get a Rift.
Syndroid
Level 7
Well, Doom 3 wasn't made with VR in mind. The size of some of the models ingame are not really accurate. Some are too big, some are too small. This becomes noticible in VR. But it isn't all that bad actually.
I still prefer a smaller worldscale than the current one for the world itself, though. Only downside is that human npc's (especially their heads) become a little too small then. 😄
