07-25-2014 10:25 AM
07-26-2014 11:08 PM
07-28-2014 01:21 PM
07-28-2014 08:12 PM
07-29-2014 02:25 AM
"spyro" wrote:
So would it be possible to mount a High-FOV-wecam along with a Rasperry Pi + WiFi module on a quadrocopter or a RC car, stream the video to a notebook where it's processed for the Rift? That should work because the really latency critical headtracking would be handled locally, right?
"molton" wrote:
It would be cool to have the option to run it at 1280x800 for the DK1, but I'm sure this looks even better with a DK2.
"molton" wrote:
Where exactly are those settings saved? If they are saved with the pictures it would be awesome if you start a website where people can upload slideshows.
07-29-2014 06:58 AM
"mrjazz" wrote:If I were you I'd make some kind of product out of this because it's awesome, and I'm broke 🙂 I don't know what kind of libraries your using with all the licencing nonsense that might make that difficult. if you do want to share the source code I could probably find some time to work on externalising the settings to an xml file or something like the Thumbs.db file in windows but for LiveViewRift. After all, it's a feature I want 🙂 I've worked with qt a tiny bit before, I think all I did was turn an opengl qt program into a wxwidgets program, I've worked with wxwidgets a bunch more, but they are very similar.
it could be a good idea to add an option to store the settings as individual xml-files in same folder where the pictures are. (Similar to how Photoshop creates the xmp-files of raw-images.) Storing it within the exif-data of the images, could also be good for easy sharing of them.
"mrjazz" wrote:
I could add a feature to watch images on the web directly, too. Specifying an URL of a xml-file containing all needed information could for instance launch the slideshow. So basically you would click on a link in your browser and my app would be launched.
07-29-2014 09:46 PM
07-30-2014 05:04 PM
"chrispetty" wrote:
Can you provide any guidance to me on connecting to a network ip cam that I have connected on my local network.
It outputs a mjpeg video stream but I'm not sure how to configure it with the settings in LiveViewRift ?
07-31-2014 11:50 AM
07-31-2014 05:09 PM
