This is the second public demo and the first official VR release. The main changes vs the first release are:
-------------------------------------------------------------- This demo groups players in regions based on their location, so at first won´t be much players in the maps. Next release will allow region selection.
The available game mode in the demo is continuous deathmatch.
Damage system has been greatly improved, turret and cannon can be damaged an temporarily disabled. Tank tracks can be destroyed causing serious struggle into enemy unit. Disabled crew shout on fire. Working UI displaying tank status. Options menu with a number of options such as audio mute, crew disable, among other graphics, sound and controls options. Define game quality in runtime. New tune and radio chatter sfx. A number of graphical improvements such HD lighting and motion blur among others. Global server network enabled. Improved trees. Tree "destruction" has been disabled until proper destruction is implemented, some still can be overrun. Many other minor improvements. x-360 controller support. FULL oculus VR support build.
OoooOOops. There is an anoying little bug that when there are 2 or more players if you press esc to configure your game the mouse will not appear so the options screen will not be removable, so all messes up.... 😮
Shorting this issue with max priority.
edit: this issue has less impact in the VR version as the vr mouse is different from desktop mouse. Still the turret will rotate, and canon fire as they're not blocked as they should.
edit2: Issues on VR versions shorted. Uploading soon.
edit 3: fixed sdk 0.7 version uploading now
edit4 : 0.7 version updated. pre 0.7 is done but I need to downgrade sdk to test. I should work. but better try.
Working atm on CPU bots and new cool stuff like anime style explosions among others.
This release should have kept all the players in a single server instead of spreading them by region. Nexte release whill be there more stuff to shoot at :mrgreen:
