01-18-2022 01:31 AM
I'm using an Oculus Quest 2 and the stick on the left controller has an issue. It keeps thinking that I am moving it backwards even when I'm not, and is very slow when I try to move it forward.
Does anyone know how to fix this?
Solved! Go to Solution.
01-18-2022 07:35 PM
Not sure if this is your issue but this worked for me: Press down on the stick until it clicks then swirl it 360 degrees a few times. Worked for me.
Source: https://www.reddit.com/r/oculus/comments/eqvkg8/rift_ss_left_joystick_gets_stuck_amy_solutions/
01-18-2022 04:48 AM
Hi i have the exact same issue since a few Days with the left con. 😞 tried to remove batterys. Restarted but didnt solve it.
01-18-2022 10:14 AM
Hello, we noticed that you are still experiencing controller issues. We're here to help! After restarting or rebooting your headset, did you try re-pairing your controllers from the mobile app? If not, please click here for instructions on how re-pair your controllers.
Let us know if you need anything else. 🙂
01-18-2022 07:35 PM
