05-07-2021 09:30 PM
So I've had a Rift for about a year and I just bought the Quest 2. Can most of my games be freely downloaded to work with the Quest 2 headset without having to re-purchase ? Or can I Air Link those games to my Quest 2 ???
05-10-2021 02:26 PM
I've found very, very few games that don't work well via Air Link, as long as you have a healthy 5Ghz wifi signal and a fast wired connection between your PC and the wifi router.
Almost no games will allow you to download a Quest version after purchasing the PCVR version.
05-10-2021 03:11 PM - edited 05-10-2021 03:12 PM
Please refer to the Oculus Quest cross-buy list. You will see that many Rift Store apps are cross-buy with Quest. If you have a cross-buy version from the Rift store you will need to download it (for free) to your Quest if you want to play it standalone.
https://www.oculus.com/experiences/quest/section/2335732183153590/?locale=en_US#/?_k=uesob9
