HELP! View jumps, Sensor truncated a higher than acceptable number of frames in the last time period
fwy5505925
Sensor truncated a higher than acceptable number of frames in the last time period (expected <=1, got 2)
4 REPLIES 4
Nokuson
I am getting this as well.
ParadiseDecay
Level 8
Had my Oculus a week and also getting this, did you guys get it fixed?
☆ YouTube 'Content Creator' and 'Steam Curator' ( https://www.youtube.com/user/ParadiseDecay ) ☆ Devs! I'm always on the look out for new and interesting VR experiences! ☆ Oculus Rift CV1 ☆ Windows 10, 64 bit ☆ Intel Core i7-3770 ☆ 16.0GB Ram ☆ GeForce GTX 1060
XMerc
Yup, this is a known problem with that card (and others). I have the same USB 3.0 card and get the same problems. For me using the on board USB 2.0 ports work much better...not a perfect solution but works well enough that I can deal with it until Oculus get a firmware update out to fix this.
ParadiseDecay
Level 8
I've tried my USB 2.0 but I'm still getting the same issues?
