Help please! Air-Link Problem
rehash4
Hi folks! First post here.
I tried using Air Link and ran into a problem , I've been searching web and forums for solution and can't seem to find one that works. I would want to see if anyone could help me 😞
I activate Air link , found my pc , connect them together with the codes everything works fine. When I click on air-link , it automaticly detect my PC , I click on launch then I see a white screen for 1-2 sec , then it flashes really quick for 3 secs and I end up seeing a messed up black / grey screen. All I can do from now on is close air link and open it back and it always does the same thing!
I have a beast PC so clearly not a performance problems.
Amd 5900x
32gb ram
6800XT GPU
1GPBS internet
No inboard graphics.
I tried turning off windows game mode , graphics card update to latest, went to diag tool , the diagnotic oculus software with the default settings , rebooting pc , rebooting oculus , repairing oculus software etc.. Still that crash at the start 😞
Did anyone run into this and found a fix?
Thanks
0 REPLIES 0
