I need a little help with something...
MelodyIsAGamer
Alright, so basically...
I've been trying to pair my brand new Oculus Quest 2 to my Windows 10 computer, and as an teenager, I can't seem to actually make things work out. Somehow, the Oculus app seems to be saying that the headset is connected, but when I look inside my VR, all that I see is the pair thingy. I'm not the smartest person, so this is confusing. Is the wi-fi bad? Is it connected badly? I checked and both seems fine. Maybe I just need a phone instead of a PC to do it... (Like what my sister did.)
1 ACCEPTED SOLUTION
Accepted Solutions
kojack
Volunteer Moderator
Volunteer Moderator
The initial setup must be done with a phone (android or iphone).
After it has been set up, you can then connect the headset to a PC if you want to play PC VR games instead of native Quest games. The PC can't do the setup step that the Quest needs to begin working.
andrewP777
Use your contoler and click "yes" when it asks to pair.
kojack
Volunteer Moderator
Volunteer Moderator
