07-28-2022 09:06 PM - edited 07-28-2022 09:11 PM
You guys might be familiar with the sidequest as a lot of people use it to enhance their performance. Recently I've tried to make Content on the Quest 2 and so far it seems pretty easy until I run into one problem. The oculus quest to records at a 1 by 1 ratio making the recording a bit squared. I thought it'd be easier to go on YouTube and find a tutorial on there but I was wrong. Every solution I try to either mate my gameplay lag from my point of view and even made the recording look bad. What are some good side quest settings that don't necessarily make my gameplay lag from my view but also doesn't make the recording look bad
