Showing results forย
Search instead forย
Did you mean:ย
Low FPS Using Oculus Link on Quest 2
ben_lipkin
I've been having some serious performance issues when using the Quest 2 Link with my PC. Everything is an annoyingly low framerate, and many textures are super fuzzy and muddy. This is true as soon as I enable Link, and is pretty consistent across games. I tested using Star Wars: Squadrons, and I honestly didn't notice much of a framerate difference between Low and Ultra, so I don't think it's my PC.
Here's what I've tried with no effect:
Set Priority of OVRServer_x64.exe to realtime
Turned off supersampling in SteamVR
Downgraded my AMD GPU driver from 20.12.1 to 20.9.1
Nothing has helped, and sometimes the link will stop working altogether and not allow me to connect.
My specs:
CPU: AMD Ryzen 9 3900x 12 core
GPU: AMD Radeon RX 6500 XT
32 gb RAM
Thanks!
PITTCANNA
Level 11
Heres the truth about the quest 2 link performance, you need a massive gpu and cpu to take advantage of the near 4 k full resolution it requires.
The gpu you have i believe can only get 50 to 60 at 4k.  You are rendering 2k per eye.
ben_lipkin
I wouldn't mind running at 50 or 60 fps. As it is, all I'm getting is in the 10s or 20s. This is also regardless of the game or graphics settings I am using and regardless of the resolution I set in the Oculus PC app.
