No audio when casting microphone-enabled applications on Quest 2
opteragroup
Hey all,
I've been struggling with this for almost a week now and found no solution. I am trying to stream my headset via casting but the audio goes away every time I load an application that uses a microphone. It works in Oculus Home and other games (like Beat Saber) but when I tried VRChat or any other social applications it no longer streams any audio.
Does anyone have a solution for streaming/casting microphone-enabled applications?
4 REPLIES 4
PITTCANNA
Level 12
Hey all,
Unfortunately it doesn't capture voice a limitation of the phone app.
opteragroup
PITTCANNA said:
Hey all,
Hi PITTCANNA,
Thanks for the reply. I understand that it doesn't capture my voice but I'm confused on why the game sound is totally silent. I tried using both Oculus Developer Hub and using webcasting (oculus.com/casting) as well and it just goes silent when the app enters the stage where the microphone is enabled.
PITTCANNA
Level 12
PITTCANNA said:
Hey all,
Hi PITTCANNA,
VR chat doesn't allow it due to privacy and other permissions because other users voices are going.  Some social games locks out casting.
GD73FIVR
hey 🙂
did u find a solution 2 that?
coz i have the exact same problem but couldnt find an answer anywhere...
for me its 'eleven table tennis VR' - all good when i start the game but after a few seconds it goes silent...
also,do u know if there is there a way 2 record the quest2 audio and mic with OBS?
