No power or signal | Risft S
M0rrr1tz
Hello, i have a problem with my rift s. When i plug in the Display port and the usb 3.0 port, nothing happends. No orange or white light in my rift s and the software cant detect the headset. Pls help me!
4 REPLIES 4
DigitalDeejays
First time using it? Or that came suddenly?
Oh and let me know your hardware :smiley:
kprnks
The same for me, there is no light when plug it in. I've used it 3 months before the problem occured.
XxJah0vaxX
Just got mine today same problem only had power for maybe 5 minutes then stopped could not even finish the setup
HardGlock
@kprnks I am having the exact same situation as you.  Has Oculus support helped you at all?
