12-04-2021 06:47 AM
I dont get any sound in VR with oculus Link and the oculus virtual audio device is completly missing.
It worked for a long while but not anymore.
YES I tried looking if its disabled.
YES I tried restarting my Quest 2.
YES I tried restarting The oculus app.
YES I tried restarting my PC.
YES I tried using the oculus device Audio settings.
YES my Oculus App AND Quest 2 has the latest updates.
YES I tried repairing / reinstalling Oculus.
Before all of this happened I had a Problem that oculus Link didnt work at all.
My Specs (In case you need it.)
GTX 1650
8 GB RAM
AMD Ryzen 5
12-04-2021 07:10 AM
Could you put the actions in the order you've actually followed (like uninstall -> restart windows -> install oculus app etc.)?
12-05-2021 04:52 AM
First oculus stopped working.
Then I fixed it.
Then another problem accoured I dont actually remember what it was.
Then I uninstalled and reinstalled oculus
Then the sound problem acoured. >> restarted Oculus >> restarted Headset >> restarted my PC >> tried solving it.
I dont really want to reinstall the app again, because my internet speed is like 400KB per sec. average.
12-06-2021 01:26 AM
So the Oculus Virtual Audio device does not show up as a Audio input and Output device in Device Manager?
You can try to manually add it by installing a new "legacy" device.
In the Device manager are the following steps:
- Click Action
- Select Add legacy hardware
- Click next
- Install the hardware that I manually select from a list (Advanced)
- Select Show All Devices
- In the Manufacturer list select Oculus
- In the Model list select Oculus Virtual Audio device
And finish the install.
Reboot to see if this helped.
12-06-2021 07:54 AM
It somehow fixed itself already.
I don't know what I did but it shows up again. I hope it works now.
