Quest 2 not working for wired connection
Jayson115
I don’t know how to explain it but I’ll try...
when you connect the quest 2 a little box pops up with a saying allow pc to connect to quest 2 and I click allow then another screen pops up and asks to display and I also click yes I had no issues with connecting until I got an update software thing and that’s when I couldn’t connect
1 ACCEPTED SOLUTION
Accepted Solutions
Jayson115
This is fixed now
4 REPLIES 4
PITTCANNA
Level 11
if your doing link.
make sure you have the occulus app installed on a compatible computer (meaning fully compatible with link requirements, rift s and link are different requirements)
power on the quest until your in the home environment
connect a compatable usb 3.0 cable in
the first prompt you must "deny"
the second prompt you must click "enable link"
I have the oculus link official cable and I do have the app Bc I used my vr since Christmas what I am saying is all of a sudden after this software update it shows 3 dots but then goes back to main menu
Reznik-6
I am having the same exact issues.  Reinstalled video drivers, oculus software, factory reset on headset.  No joy. Keeping eye on this if there is a solution.  It shame you spend more time troubleshooting link than playing.
Jayson115
This is fixed now
