Rift Old Poor Tracking Quality Problem - After PC Sleep
Sabrejet
Protege
Hey, it's been a huge while since I've been here.  I wanted to see if the users have found a fix for this problem.
At first, I was having the "Computer won't sleep due to OVRService running." So I would stop the service a few times, and now most of the time my computer will sleep without having to stop it anymore.
What happens now, and probably happened a lot in the past; When the computer wakes from sleep, my sensors report Bad Tracking Quality, and
USB Driver Update Recommended.  This seems to happen only after sleep.
Oculus Tray Tool earlier today reported: Fresco USB has entered power saving mode (right click to disable.)  I had done work on Device Manager and Power Settings to disable that earlier, but I right clicked and did it anyway.
Right now I'm looking at the same thing happening.  OTT is not reporting any errors this time however.  I don't really use OTT anymore, but thought it could give me some info.
I have the Inateck 7-Port USB 3.0 PCI-E Card KTU3FR-5O2U
850W PSU, X370 Killer SLI/ac Motherboard.
Hybrid Sleep Off.  (Now trying On)
Hibernate:  Never
All drivers are super up to date.  The original Inateck drivers seemed to be a problem if I remember.  At this moment, sleep seems to be the culprit.
One more thing to add:
Replugging usually fixes the Poor Tracking (but not always!) but it still says USB driver update recommended.
Sabrejet
Protege
yep even hybrid sleep.
Sabrejet
Protege
Okay. Good news. This very old problem isn't solved, but it seems that after a while, Windows does get the drivers and sensors going and working normally after a while.  Right out of sleep it does the poor tracking quality thing, but after a while of not sleeping, it sorts itself out.
