So O Was Using Link Cable To Connect My Oculus To My Pc But it randomly kicks me and says pc disconn
Tragic10
Hey there Tragic10! We know that PCVR is exciting, but we also know that troubleshooting for PCVR is tedious. We'd be happy to swiftly guide you to the awesome VR adventures you want, but we'll need to get some more information from you regarding your computer setup. Please contact our Support team with your Oculus logs, and one of our dignified agents will gladly grant you further insight! To gather your logs, follow the steps below:
    • The above link is the default directory. Bear in mind that if you installed the Oculus PC app to another drive you will need to update the command with the correct file path.
