03-12-2022 08:33 AM
Anyone else having an issue with the Putter size being reduced in half lately? It almost like I need to get on my knees to get it to function properly. I have tried to reset the putter, but it doesn't restore it to the normal length.
03-20-2022 03:44 PM
I'm having the same issue it's annoying
03-20-2022 03:52 PM
do you have the height of the floor set?
redo your gaurdian, and touch the controller on the ground when it says confirm floor height.
03-21-2022 08:54 AM
Hey there! We wanted to jump in and point you in the right direction for your club adjustments. The game's developer FAQ resource has instructions on how to adjust your club length: https://www.proputt.com/faq. We'll go ahead and post the instructions here for you as well:
How do I adjust my club length?
Access settings with the B/Y button, or go to settings in the main menu and choose "Putter Length". Use the thumb stick up or down to get the right length to your preference. Pull trigger to confirm the size adjustment.
We hope this helps you with your swing!
01-12-2023 05:04 PM
I'm sure everyone with this issue appreciates your answer, but in Golf +, even after resetting the floor level in the guardian, the issue returns after playing a few holes. Ideas???
