If your home network is running on the 2.4Ghz frequency, its signals can potentially interfere with the headset tracker, causing a stutter effect inside the headset. Not only is it annoying, but can become sickening if not dealt with.
It took me a while to narrow down the cause of my own wifi interference. I had no problems with the Rift in another room where the same computer was hard-wired to my network, and I didn't have the wifi adapter plugged in. I was attempting to use Virtual Desktop to play other games on a giant virtual screen (which is incredible, btw). Naturally, I thought my graphical issues were being caused by the games or the combination with Virtual Desktop. Eventually I realized that the glitch was not only happening in Virtual Desktop, but in Oculus Home. The only difference in setup from one room to the next was the wifi adapter. A quick test of turning the radio receiver off on the wifi showed it to be the cause of the problem.
Solution: Connect to your wifi using a different band if possible. Many routers are dual-band and also broadcast @ 5Ghz.
Interesting. I've been getting intermittent stutters and comments from others in social vr that it appears that my head is jumping around. I use both 2.4Ghz and 5Ghz. I'll try changing bands to see if the symptoms go away. I feel for those in college dorms with tons of signals floating around....
Get Help
