power adapter
amitm2711
hello!
can i use a power adapter type c with 20w for ouculus quest 2?
i can't find in my countrey 10w.... please help me.. any solutions?
1 ACCEPTED SOLUTION
Accepted Solutions
Yeah, a genuine Apple 20A USB type C adaptor would be fine.
Intel 5820K OC@4Ghz, Titan X (Maxwell), 32GB Corsair Vengeance DDR4, ASRock X99 Taichi, Samsung 500Gb 960 Evo M.2, Corsair H100i v2 Cooler, Inateck KTU3FR-4P USB 3 card, Windows 10 Pro v21H2 (19044.1706)
7 REPLIES 7
DaftnDirect
Volunteer Moderator
Volunteer Moderator
Hi @amitm2711 the power rating of a USB adaptor is just the maximum power that it's rated at delivering, what it actual delivers will depend on what you plug in. So if you plug in a Quest that takes 10W, a 10W and a 20W adaptor will both be ok delivering 10W.
thank you very much for the quick answer! So just to understand, why oculus recommend to use only 10w adapter power If it doesn’t matter the watts of the adapter?
thanks again
Oculus can really only recommend their own adaptor because they know it's been designed and tested at a continuous 10W for long periods without overheating or presenting any other hazard but there are some nasty cheap power supplies out there. ebay and amazon are awash with fake and untested stuff so if you don't buy from a trusted retailer, it can sometimes be a bit of a lottery what you get with regard to electronic devices, particularly USB power supplies.
Plus there are adaptors that are rated less than 10w which wouldn't deliver enough to keep the Quest charged during play or would take longer to charge a Quest during stand-by.
Thanks a lot u really enriches my knowledge 🙂 so if i have a adapter power 20w original for iphone it is safe for the oculus?
Thanks u, really appreciate ur help!!
I've got a 9W (5.2V 1.8A) Amazon Fire 8HD adapter.  Is this fine to use on the Quest?  I'm assuming it would just charge slightly slower.  I just don't want to have multiple adapters for different devices.
