12-02-2018 03:01 AM
12-02-2018 04:28 AM
12-02-2018 04:49 AM
12-02-2018 05:15 AM
TomCgcmfc said:
I had a similar problem with one of my super speed USB ports. I got into device manager and uninstalled it. Then restarted my pc and let windows find the correct driver. Worked fine ever since, that is no more yellow warning triangles on that usb pot.
12-02-2018 09:56 AM
12-02-2018 12:04 PM
TomCgcmfc said:
Sorry but it’s not really clear what you actually did. Maybe you need to add an Oculus approved usb 3.0 board and connect 2x sensors and Rift to it. Might be best to try working this out with Oculus support again imho.
12-02-2018 01:44 PM
If you look at the Oculus Support info you will find that they recommend the Inateck Superspeed 4 Ports PCI-E to USB 3.0 Expansion Card. Looks pretty inexpensive, ~$25.
Sephiroth986 said:
any good cheap board? it's the unique solution a pci board?
12-02-2018 02:22 PM
12-02-2018 03:07 PM
12-03-2018 11:21 AM
TomCgcmfc said:
Well that’s what appears to be recommend by Oculus. If you are unsure just ask Oculus support I guess. Kinda hard to believe this did not get addressed when you first started a suppprt ticket. Sorry but I really cannot help you further but I’m sure you will sort this out eventually. Good luck with all that.
