Oculus Developer Hub 2.1 - Opens with a blank window
Markvw
I use macOS Montery (Chip: Apple M1) and Oculus Developer Hub (ODH) 2.1. But when I open the app it hangs on a white blank window. Rebooting the system, reinstalling does not change that.
A work around is to remove version 2.1 and download and install the earlier 2.0 version. Then everything works again. Hopefully they can fix this.
3 REPLIES 3
nerd0
I have the same problem. Like you, I'm running macOS Monterey 12.1 on an M1 Max.
v2.1 hangs with a blank, white window.
Downgrading to v2.0 works.
Lumoti
Same problem on windows 10.
2.0 roll back also fixes problem.
kevinagnes
Same issue with macOS BigSur 11.5.2 on an M1. Haven't tested 2.0 yet.
