The OVRManager.boundary object is not getting configured and outputs useless information.
Unity version: 2019.3.0f6
Oculus Integration version: 13.0 (Feb 7th 2020)
Oculus Android Package: 2.38.6
Oculus Desktop Package: 2.38.4
Not using any of the new/legacy XR packages.
Not using any Steam stuff.
OVRManager is in a fresh scene, fresh project, on the CameraRig prefab.
Virtual Reality supported is ticked. Android is selected in build settings.
Play in editor runs in the Quest fine.
Sample code and results:
void Update() { Debug.Log("GetConfigured is " + OVRManager.boundary.GetConfigured()); // False Debug.Log("GetDimensions(Outer) is " + OVRManager.boundary.GetDimensions(OVRBoundary.BoundaryType.OuterBoundary)); // Fluctuates between around (4.6,0,0) and (6.4,0,0) Debug.Log("GetDimensions(Play) is " + OVRManager.boundary.GetDimensions(OVRBoundary.BoundaryType.PlayArea)); // Fluctuates between around (7,0,0) and (14,0,0)
Debug.Log("GetGeometry(Outer) Length is " + OVRManager.boundary.GetGeometry(OVRBoundary.BoundaryType.OuterBoundary).Length); // Array length is always 0 Debug.Log("GetGeometry(Play) Length is " + OVRManager.boundary.GetGeometry(OVRBoundary.BoundaryType.PlayArea).Length); // Array length is always 0
This is a confirmed bug. I can't post a link to it but you can find it if you search "OVR_CAPI functions for Boundary info don't work with Quest + Link"
