Quest project builds and runs, but stays stuck on 3 dot loading screen
Sprakle
I followed the official instructions for setting up Unity for Quest development.
I tried to build using the included example scenes. The build works fine, but when it runs on the quest, it stays stuck on the animated 3 dot loading screen.
The ADB logs show no errors, and even show various Unity logs while stuck, such as the focus gained and lost events. So I'm pretty confident that the build is running, just stuck behind the loading screen.
I've tried from scratch several times, factory reset my Quest, messed with all sorts of build settings, but can't make any progress.
I've attached the compiled APK in case that helps, and the full ADB logs.
Any suggestions?
Running on Unity 2019.2.21
3 REPLIES 3
Any progress on this?
I am dealing with the same issue.
BitPunked
Are you using by any chance Unity Cloud Build? I had that same issues from any builds originating from Cloud Build.
I could build it locally, and the game would work perfectly.
JeffNik
Level 7
@MadeinBrooklynGames - (the orig post is very old)
I had similar problems in the past - for me, the VR system wasn't being initialized. Assuming you are using a recent version of Unity, the Oculus Integration package and the Unity XR Plug-In Management system, check the following:
1) The XR Plugin Management has been installed, and the Oculus plugin activated
2) "Initialize XR On Startup" is checked
3) Confirm that you have removed the defaul main camera, and replaced it with an instance of the "OVRCameraRig" prefab.
4) If you arent using the Oculus Integration package, make sure the you have converted your default main camera to an XR Rig (right click it -> XR -> "Convert Main Camera to XR Rig" (which adds a "XRRig" script to it)
Hope some of this solves your issue.
