Unity 5.1 VR, Problem with Linear Color
Nyro
Hi guys, I'm having some problems with the new Unity 5.1. When I try to use linear color spacing and the "virtual reality supported" option enabled, I get the following on may Console:
[CAPI] LibOVR module is located at C:\Windows\SYSTEM32\LibOVRRT64_0_6.dll
SUCCEEDED(hr)
depthSurface == NULL || rcolorZero->backBuffer == depthSurface->backBuffer
refCount == 0
The Oculus(DK2) displays the health info and then goes black. Is that a bug or linear color are not supported?
8 REPLIES 8
scottsquires
Check the release notes. I think there is a known issue with linear.
Curtis
I am having the same problem. Just checked the known issues and sure enough:
"Apps that use linear lighting won't render. Recommended to use gamma for now."
huh. Hopefully they fix this soon
Curtis
Just saw this on the official unity forums:
http://forum.unity3d.com/threads/unity- ... ed.332316/
Thanks for the update, is this going to be fixed in the patch? This isnt a trivial setting... thanks!
Fix is currently scheduled for patch 2 which is either next week or the following week.
So not too bad 🙂
sisermann
The problem is back with 5.1.3f1 ...
sisermann
5.1.3p1 has the same problem ... linear color not working
cybereality
Level 16
Thanks for the report. I will share this with the team.
JoaquinGM
Same here
Joaquin Gracia ITAINNOVA - Multimedia Technologies
SCDarky
They seem to know about it: http://forum.unity3d.com/threads/psa-5- ... es.350644/
My question is, does the 0.7 Runtime work with 5.1.3 regardless?
EDIT: NVM, it does not seem to http://forum.unity3d.com/threads/oculus ... st-2271072
