animating hand mesh using XR Rig?
foj
Wonder if anyone has experience of using the Model section under XR Controller script on the LeftHand/RightHand Controller of the XR Rig? I was hoping it may be possible (as in easy) to use the animated hand mesh from the old Oculus package - tick on Animate Model and it all works    😄
Currently only supporting Oculus Rift, I just really want animating hands in. Any help, documentation or tutorial links will be appreciated. Thank you.
djlins3
Hi there,
Did you ever get a solution to this? I'm in exactly the same pickle you were at in May.   :smile:
