10-26-2021 11:48 AM
I'm unable to connect the Oculus Quest 2 w Unreal Engine 4.27. Under launch ( Unreal Engine), I don't see my Occulus Quest
1. I've installed the Oculus Developer Hub - Working
2. I downloaded the Android Studio - Working
3. Unreal Engine: I opened the SetUpAndroid Windows Batch and activated it.
4. I'm using the VR template in Unreal Engine 4.27. I've watched a couple of You Tube videos about settings and plugins. I think this is what the problem is.
Are there any links you can suggest? Also open to hiring someone to walk me through this.
Thanks,
Hector
10-27-2021 05:13 AM
If you haven't already, enable Developer Mode on your Oculus. You can do that from the Developer Hub.
Then, open `<user>/AppData/Local/Android/platform-tools` directory in the terminal and run `.\adb.exe devices`. There should be an entry for the device.
11-10-2021 12:10 PM
If you are talking about previewing VR in editor with the Quest 2 you have to enable the Link when it asks you to on first connect, then you can do the VR preview in Editor. Might have to re-launch editor once Quest 2 Link with PC is done.
