Quest 2 not showing on unreal launcher!!! Help
jacqueskaufmann
After steam VR upgrade the driver... My quest 2 doesn't show up on unreal launcher...(it was showing before)
I can play the game os the PC using vr preview, the quest show as a drive in the explorer...
Any one know how to fix this?
Thanks
GreatOceanGames
Did you manage to fix this im having the same issue
sackbut
If you open a command prompt and run "adb devices", does it list the device as connected? I was having a problem where the Q2 wouldn't show up in UE until I did this once manually.
