11-18-2022 03:05 AM
It looks like my AirLink isn't working anymore for some reason after the recent update.
My PC Oculus app is up to date (I also tried to reinstall it), the visor software is up to date.
The cable connection works, mirroring on the phone works, but via AirLink it won't connect.
It recognizes my PC name, but when i click on it, it says it can't connect to it after 5-6 seconds.
I'm on a 5Ghz WiFi net, the PC is connected via cable to the same router and there's no active firewall.
Any help?
11-18-2022 04:25 AM
So it's solved.. by doing the only thing I didn't tried: factory reset!
