08-02-2022 06:26 PM
While using oculus quest link my games were running very badly and I noticed quite quickly that anti-aliasing was most likely the problem. So I go to setting and try to turn it off but when I click it the toggle stays the same. I search for hours but still can’t find a fix.
08-04-2022 02:45 PM
Hey there! Thank you for notifying us of this issue. You should be able to turn off the anti-aliasing feature! It seems like there's a bug or it's a system issue. We see why you have a concern, and we were happy to help out!
Try these steps below:
Make sure to enable cloud back up before you do a factory reset with these steps. If you still can't use this feature properly, we recommend you submit a support ticket with one of our specialists as we do not have the tools needed to assist through the forum. They will be happy to go over your next options with you!
10-19-2022 11:53 PM
Did it work?
01-05-2023 06:19 PM
have exact same problem with anti-aliasing and when il look on web to get a fix issu, realize there are many many people that have this issu also and there is no issu to turn it off even solft or factory reset. you guys have to make a patch to fix this trouble, is really a pain.
for tips we mean the anti-alising from air link graphic option both options in this page cant be turn off. can we hope a patch soon, if i check how many people who have this bugg from like over 8 months by now that not acceptable.
01-05-2023 06:40 PM
Hey there @Snyfex13, we see you are having issues with anti-aliasing. We understand how inconvenient this may be, but we're here to assist you all that we can. Seeing as you have performed a reboot and factory reset, we want to ask you to reach out to us at Meta Store Support. We have better tools and resources to help you with this matter. We hope this information was useful, and we wish to hear from you soon!
01-05-2023 06:45 PM
manage sstore support dont have any information about it, ill was looking for it for like days, can you just link me or tell me HOW THE HELL TO TURN THIS OPTION OFFFFFFF or how to reset all to default, ill deleted all headset on oculus, and factory reset to reconnect it back to normal but option still ON.
06-15-2023 06:20 PM
5 months later, same problem, i want to hit this thing with a tire iron and then send it back for a new one
06-23-2023 12:45 PM - edited 06-25-2023 03:54 PM
