Bluetooth Connection Problem with Gaim Controller
Elflojothibell
Hello,
I have an occulus Quest 2 and the Hunter Game from Gaim with an Controller for the rifle. For a Long time the system works, but know i have the Problem, that the Trigger (Controller from Gaim) dosen't connect with Bluetooth. I can find it with the VR glasses. If i want to Connect it, nothing change. Ist looks like the Meta Quest 2 don't want to Connect to the Trigger. What can i do? Ist there an Firewall or something like that? Please Help me.
zsombor86
I also have the same problem with Gaim trigger. I received a new trigger from Gaim but that does not solve the problem. Do you have any updates on the issue?
