08-31-2022 02:28 AM
I unfortunately can't get the Oculus Quest 2 to run in Unity's play mode.
My system info:
OS: Win10
CPU: i7
RAM: 16 GB
GPU: RTX 3060 Laptop (driver version 516.59)
Unity version: 2021.3.8.f1 (older versions do not work either)
XR Plugin Management: 4.2.1, Windows Settings: Init XR on Startup checked, Plug-in Providers Oculus checked
Quest 2 system version: 37314400808900000
USB debugging allowed
Oculus Link active (connected via USB 3.0 cable)
When I enter play mode the following warning appears: "Unable to start Oculus XR Plugin."
What I have tried so far:
Ouest 2 reset to factory settings
Reinstalled Oculus environment and drivers
Unity reinstalled
Unfortunately without success. But I rule out a hardware problem, because with Unreal 4.27 a preview in the editor works fine. What do I miss?
09-05-2022 10:19 AM
Hey friend!
We see you got yourself some unity situations going on. Worry not, we'll point you in the right direction! We have a specific forums for all type of unity scenarios. Which of you are more than welcome to mosey on over to those Unity Forums. You'll find all types of awesome folks talking about all different type of unity scenarios! This would be the best place to go for all your Unity needs!
09-05-2022 11:46 PM
Well, okay...
