Can't set up device on ODH
CountDuckula
I just cant set up the headset into my ODH app from PC even in the Oculus mobile app doesn't work, I have tried everything for the las 4 days and nothing. On my ODH app stays at connecting and on the mobile app says headset not found.
biscuitsngravyy
Meta Quest Support
Meta Quest Support
Hey @CountDuckula, you may have better results posting this in our Developer Forums since it's directly related to the Oculus Developer Hub. As for the issue itself, if you haven't already, check out the support article on ODH here.
Hope this helps!
