Connecting to my PC
I really need help with my PC I don't know if I supposed to have a gaming computer or a gaming laptop but I'm using a regular laptop to connect my Oculus and won't connect I'm using a USB type c to connect to my PC but it won't connect
1 ACCEPTED SOLUTION
Accepted Solutions
FunkyTanuki
Meta Quest Support
Meta Quest Support
Hey Javon,
I've linked the PC requirements to use Link with your device HERE. It'll outline the minimum and recommended requirements. Laptops are an even trickier subject as the Link cable is very picky about the laptops, but if you make sure it meets the requirements mentioned on the list then you should be golden.
"Swap meat for chrome, live a BD fantasy, whatever, but at the end of it all, it's the code you live by that defines who you are. " - Johnny Silverhand
FunkyTanuki
Meta Quest Support
Meta Quest Support
Hey Javon,
