11-06-2022 07:37 AM
My left controller joystick will not go left. All other directions work but when I try to go left it goes right. It's only full deflection. If I push to the left a little it's fine, I'll move left in the game. But if I go full left, I go right in the game. This happens in all games. What can I do to fix this?
11-08-2022 05:47 PM
Hey hey! Sounds like someone needs to give your joystick a compass so it knows where it's going! Let's see if we can get it to learn its left from its right.
Here are some controller/joystick troubleshooting steps you can try:
Remove the batteries from your controllers for at least 10 minutes, then replace with new batteries.
When powering on your controllers, ensure that the Analog sticks aren't being held in any direction and are at rest in the neutral position.
Try un-pairing and re-pairing your controllers in your mobile app.
While this isn't a joystick drift issue, you may have some luck with adjusting and recalibrating the dead zones of the controller in your headset settings:
Go to Settings
Go to Controller Settings
Under Joystick Deadzone and Range, select the joystick which is having issue
Follow on-screen instructions to recalibrate the joysticks deadzones
And if after trying all of that, your controller is still a bit directionally challenged, you're going to want to go ahead and reach out to the support team by starting a ticket here: https://metaque.st/Support
