DK2 unable to run on WIP desktop?
Nickoplier
Before I even let you reply that it is incompatible or will never work, I went back into my multi-boot and tried Oculus Runtime 7.0.0 beta on 8.1 and same results, and same error.
The Oculus Rift also worked with a previous older version flawlessly on Windows 8.1. I would be able to turn on the PC, and the Oculus Rift DK2 would be detected instantly and run fine.. Is Oculus now forcing me to get a GPU just to play with a development kit?
PS. This is an Intel Core i7-4790k. Not in a laptop, it's in a desktop..
I have tried the Oculus Runtime Version 7.0.0 and 6.0.1 on both Windows 10 and Windows 8.1. The Windows 8.1 was completely fresh and installed 5 hours ago with all windows updates added. Both returned the same error "HMD powered off, check HDMI connection." I have changed my connection from the DVI to HDMI cable and a HDMI port too. The DK2 displays the desktop on both Windows 10 and 8.1, but the runtime service keeps asking to check the HDMI connection. The logs are reporting a lot of missing files that I believe are only available if you install the necessary NVIDIA or AMD drivers when I don't have a GPU card at all and the majority of the games I played with an old version of the Oculus Runtime would render perfectly fine and not stutter. I have even moved back and forth from USB 3.0 and 2.0.
QuickLog:
Display Driver Version: C:\WINDOWS\system32\OVRDisplay64.dll not found
Positional Tracker Driver Version: 1.0.11.0
Intel(R) HD Graphics 4600
Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Connected to OVRService server.
Debug Log Output:
"Time": "2015-09-05_21:20:54",
"SDK Version": "0.7.0.0",
"Service Protocol": {
"Major": 1,
"Minor": 7,
"Patch": 0
"RemoteProtocolVersion": {
"Major": 1,
"Minor": 7,
"Patch": 0
"Service Running Time": {
"Hours": 0,
"Minutes": 11,
"Seconds": 29
"System Specifications": {
"Operating System": "Microsoft Windows 10 Pro",
"Processor": "Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz",
"Graphics Adapters": [{
"Name": "Intel(R) HD Graphics 4600",
"Video Controller RAM (MB)": 1024,
"Driver Version": "10.18.15.4256",
"Video Mode": "1920 x 1080 x 4294967296 colors"
"Total RAM (GB)": 8,
"USB Tree": [{
"name": "Standard Enhanced PCI to USB Host Controller",
"deviceid": "PCI\\VEN_8086&DEV_8CA6&SUBSYS_50061458&REV_00\\3&11583659&0&E8",
"caption": "Standard Enhanced PCI to USB Host Controller",
"manufacturer": "(Standard USB Host Controller)",
"Devices": [{
"name": "USB Root Hub"
"manufacturer": "(Generic USB Hub)",
"name": "Generic USB Hub"
"deviceid": "PCI\\VEN_8086&DEV_8CAD&SUBSYS_50061458&REV_00\\3&11583659&0&D0",
"Devices": [{
"name": "Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)",
"deviceid": "PCI\\VEN_8086&DEV_8CB1&SUBSYS_50071458&REV_00\\3&11583659&0&A0",
"caption": "Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)",
"manufacturer": "Generic USB xHCI Host Controller",
"Devices": [{
"manufacturer": "(Standard USB HUBs)",
"name": "USB Root Hub (xHCI)"
"manufacturer": "Compatible USB storage device",
"name": "USB Mass Storage Device"
"manufacturer": "(Standard disk drives)",
"name": "WD My Passport 07A8 USB Device"
"manufacturer": "Western Digital Technologies",
"name": "WD SES Device"
"name": "USB Composite Device"
"manufacturer": "(Generic USB Audio)",
"name": "TRITTON 720+ Headset"
"manufacturer": "Microsoft",
"name": "Speakers (2- TRITTON 720+ Headset)"
"name": "Microphone (2- TRITTON 720+ Headset)"
"manufacturer": "(Standard system devices)",
"name": "USB Input Device"
"name": "HID-compliant consumer control device"
"name": "HID-compliant vendor-defined device"
"name": "HID-compliant mouse"
"manufacturer": "(Standard keyboards)",
"name": "HID Keyboard Device"
"name": "HID-compliant system controller"
"manufacturer": "Oculus VR",
"name": "Oculus DK2 Tracker"
"manufacturer": "Oculus",
"name": "Rift DK2 Sensor USB"
"name": "HID-compliant device"
"Drivers": [{
"Path": "\\system32\\OVRDisplay64.dll",
"Version": "C:\\WINDOWS\\system32\\OVRDisplay64.dll not found"
"Path": "\\system32\\OVRDisplayRT64.dll",
"Version": "C:\\WINDOWS\\system32\\OVRDisplayRT64.dll not found"
"Path": "\\syswow64\\OVRDisplay32.dll",
"Version": "C:\\WINDOWS\\syswow64\\OVRDisplay32.dll not found"
"Path": "\\syswow64\\OVRDisplayRT32.dll",
"Version": "C:\\WINDOWS\\syswow64\\OVRDisplayRT32.dll not found"
"Path": "\\system32\\drivers\\RiftEnabler.sys",
"Version": "C:\\WINDOWS\\system32\\drivers\\RiftEnabler.sys not found"
"Path": "\\system32\\OVRDisplay32.dll",
"Version": "C:\\WINDOWS\\system32\\OVRDisplay32.dll not found"
"Path": "\\system32\\OVRDisplayRT32.dll",
"Version": "C:\\WINDOWS\\system32\\OVRDisplayRT32.dll not found"
"Path": "\\system32\\drivers\\OCUSBVID.sys",
"Version": "1.0.11.0"
"Video Device Tree": [{
"VRAM (MB)": 112,
"Monitors": [{
"Name": "\\\\.\\DISPLAY2",
"Width": 1920,
"Height": 1080,
"Refresh Rate": 60
"Name": "\\\\.\\DISPLAY1",
"Width": 1920,
"Height": 1080,
"Refresh Rate": 59
"Name": "\\\\.\\DISPLAY3",
"Width": 1920,
"Height": 1080,
"Refresh Rate": 75
"Name": "Microsoft Basic Render Driver",
"VRAM (MB)": 0,
"Monitors": []
"Devices": []
EDIT: For some reason, the Oculus Configuration Utility now says "Oculus Rift DK2L: Ready".
I went ahead and started the demo scene, hoping it somehow was going to work, and no.
Service crashed.
Debug Log Output:
"Time": "2015-09-06_09:06:28",
"Major": 1,
"Minor": 7,
"Patch": 0
"Major": 1,
"Minor": 7,
"Patch": 0
"Hours": 0,
"Minutes": 1,
"Seconds": 45
"USB Tree": [{
"Devices": [{
"Devices": [{
"Devices": [{
"Drivers": [{
"Version": "1.2.7.0"
"VRAM (MB)": 112,
"Monitors": [{
"Width": 1920,
"Height": 1080,
"Refresh Rate": 60
"Width": 1920,
"Height": 1080,
"Refresh Rate": 59
"VRAM (MB)": 0,
"Monitors": []
"Devices": [{
"Product ID": 33,
"Product Name": "Oculus Rift DK2",
"Manufacturer": "Oculus VR",
"Serial Number": "207ZDS02PQAN",
"Vendor ID": 10291,
"EDID Serial": "H1DEM646KHC83",
"Firmware": {
"Major": 2,
"Minor": 12
"Frustum": {
"Far Z Metres": 2.500000,
"H Fov Radians": 1.291544,
"Near Z Metres": 0.400000,
"V Fov Radians": 0.942478
"Positional Tracker": {
"Calibration Value": "3f800000 00000000 43f00000 443c0000 442c734f 43bfc7da 43658ad5 42a72a60 428659f2 befbf4c7 3e94999d bdb8dd4d 3b94b3a5 ba94de7e",
"Serial": "217ZDS02PQAN",
"UUID": "H1DEM646KHC83Y00Y000",
"Firmware Version": {
"Major": 0,
"Minor": 0,
"Build": 1,
"Revision": 0
ServerLog:
09/06/15 15:04:43: [TrackingManager] Entering tracking thread
09/06/15 15:04:43: OVR::Win32::HIDDevice - Opened '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
Manufacturer:'Oculus VR, Inc.' Product:'Rift DK2' Serial#:'H1DEM646KHC83Y00Y000' Version:'212'
09/06/15 15:04:43: [TrackingManager] Broadcasting new HMD count = 0
09/06/15 15:04:43: [Sensor2Impl] Repeated 2 IMU samples: 2000 2 0
09/06/15 15:04:43: OVR::SensorDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 15:04:43: OVR::Win32::HIDDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 15:04:44: OVR::Win32::HIDDevice - Opened '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 15:04:44: [Sensor2Impl] Repeated 2 IMU samples: 2000 2 0
09/06/15 15:04:44: OVR::SensorDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 15:04:44: OVR::Win32::HIDDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 15:04:44: [FirmwareVersions] Device does not need firmware updates. We have only released new firmware for the CB2+ trackers
09/06/15 15:04:45: [Sensor2Impl] Repeated 2 IMU samples: 2000 2 0
09/06/15 15:04:45: [Sensor2Impl] Lost 2 IMU samples: 3997 2 4
09/06/15 15:04:45: BruteMatcher: Model 40 points, SampleRadius 5.0 deg, 10586 samples, 286 triangles
09/06/15 15:04:45: BruteMatcher: Model 0 points, SampleRadius 5.0 deg, 0 samples, 0 triangles
09/06/15 15:04:45: [TrackingManager] Broadcasting new HMD count = 1
09/06/15 15:04:45: Set ISO Interface to 7 successfully
09/06/15 15:04:45: [Sensor2Impl] Lost 7 IMU samples: 8993 2 9
09/06/15 15:04:45: [ExternalCamera] Skipped 1224 frames
09/06/15 15:09:29: WARNING: [CameraTimeSynchronizer] out of sync. Exposure Delta = 0.0 ms, cameraDelta = 16.7 ms.
09/06/15 15:09:29: [CameraTimeSynchronizer] successfully synchronized.
09/06/15 15:09:29: [ExternalCamera] Skipped 6 frames
09/06/15 15:09:31: [CameraTimeSynchronizer] successfully synchronized.
09/06/15 15:09:31: [ExternalCamera] Skipped 6 frames
Now after fiddling a little while, the Oculus Configuration Utility now states that the 'Oculus Rift DK2: Ready' and can open games. After attempting to open the demo, the service disconnects, and refreshes to saying that the Service Crashed.
Debug Log Output (Error and Info)
"Time": "2015-09-06_14:03:59",
"Major": 1,
"Minor": 7,
"Patch": 0
"Major": 1,
"Minor": 7,
"Patch": 0
"Hours": 0,
"Minutes": 0,
"Seconds": 15
"USB Tree": [{
"Devices": [{
"Devices": [{
"Devices": [{
"Drivers": [{
"VRAM (MB)": 112,
"Monitors": [{
"Width": 1920,
"Height": 1080,
"Refresh Rate": 60
"Width": 1920,
"Height": 1080,
"Refresh Rate": 59
"VRAM (MB)": 0,
"Monitors": []
"Devices": [{
"Product ID": 33,
"Vendor ID": 10291,
"Firmware": {
"Major": 2,
"Minor": 12
"Frustum": {
"Major": 0,
"Minor": 0,
"Build": 1,
"Revision": 0
PerfLog:
"MHash": "A11F68F80D89F2FFCBC4",
"Service": "0.7.0.0",
"OSVersion": "10.0.10240.16384",
"OSDesc": "Windows 8.1 (+)",
"Total Physical Memory": 8444321792,
"Arch": "x64",
"Graphics": {
"Adapter0": {
"Description": "Intel(R) HD Graphics 4600",
"VendorId": 32902,
"DeviceId": 1042,
"VideoMemory": 117964800,
"SystemMemory": 0,
"SharedMemory": 4222160896
"Origin": 1,
"Desc": "No ETW events",
"ErrorID": -90003
Serverlog
09/06/15 20:03:44: [TrackingManager] Entering tracking thread
09/06/15 20:03:44: OVR::Win32::HIDDevice - Opened '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 20:03:44: [Sensor2Impl] Repeated 2 IMU samples: 2000 2 0
09/06/15 20:03:44: OVR::SensorDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 20:03:44: OVR::Win32::HIDDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 20:03:44: [TrackingManager] Broadcasting new HMD count = 0
09/06/15 20:03:45: OVR::Win32::HIDDevice - Opened '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 20:03:45: [Sensor2Impl] Repeated 2 IMU samples: 2000 2 0
09/06/15 20:03:45: OVR::SensorDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 20:03:45: OVR::Win32::HIDDevice - Closed '\\?\hid#vid_2833&pid_0021#7&23f37e59&1&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}'
09/06/15 20:03:45: [FirmwareVersions] Device does not need firmware updates. We have only released new firmware for the CB2+ trackers
09/06/15 20:03:45: BruteMatcher: Model 40 points, SampleRadius 5.0 deg, 10586 samples, 286 triangles
09/06/15 20:03:45: BruteMatcher: Model 0 points, SampleRadius 5.0 deg, 0 samples, 0 triangles
09/06/15 20:03:45: [TrackingManager] Broadcasting new HMD count = 1
09/06/15 20:03:46: Set ISO Interface to 7 successfully
09/06/15 20:03:46: [Sensor2Impl] Lost 2 IMU samples: 3997 2 4
09/06/15 20:03:46: [ExternalCamera] Skipped 135040 frames
--next post--
5 REPLIES 5
Nickoplier
--/next post--
THEN the attempt to use measure under Advanced Configuration resulted in an exception occured.
Exception Info
Exception report file: C:\Users\Nickoplier.Nickoplier-PC\AppData\Local\Oculus\Configuration Utility\Exception Report (2015-09-06 20.05.56).txt
Exception minidump file: C:\Users\Nickoplier.Nickoplier-PC\AppData\Local\Oculus\Configuration Utility\Exception Minidump (2015-09-06 20.05.56).mdmp
Time (GMT): 2015/09/06 20:05:56
Time (local): 2015/09/06 14:05:56
Thread name: (not available)
Thread handle: 0x0000000000000508
Thread sys id: 8540 (0x215c)
Exception instruction address: 0x00007ff6df441a07 (see callstack below)
Exception description: ACCESS_VIOLATION reading address 0x0000000000000000
App Info
Process path: C:\Program Files (x86)\Oculus\Tools\OculusConfigUtil.exe
App format: 64 bit
App version: 7.0.0.26297
System Info
OS name: Windows 8, version: 6.2 build 9200, 64 bit, platform id: 2, service pack: <none>
Debugger present: no
Processor count: 8
Processor type: x86-64
Processor level: 6
Processor revision: 15363
Memory load: 42%
Total physical memory: 8053 MiB
Available physical memory: 4632 MiB
Total page file memory: 10037 MiB
Available page file memory: 5748 MiB
Total virtual memory: 134217727 MiB
Free virtual memory: 134217430 MiB
Display Device 0 name: \\.\DISPLAY1, context: Intel(R) HD Graphics 4600, primary: yes, mirroring: no
Display Device 1 name: \\.\DISPLAY2, context: Intel(R) HD Graphics 4600, primary: no, mirroring: no
Display Device 2 name: \\.\DISPLAY3, context: Intel(R) HD Graphics 4600, primary: no, mirroring: no
Display adapter list
Info for display adapter 0
Display Adapter Name: Intel(R) HD Graphics 4600
Display Adapter RAM: 1024 MiB
Display Adapter DeviceID: VideoController1
Display Adapter DriverVersion: 10.18.15.4256
Display Adapter DriverDate (US format): 07/17/2015
Display Adapter VideoProcessor Intel(R) HD Graphics Family
Display Adapter VideoModeDescription: 1920 x 1080 x 4294967296 colors
Thread list
Thread handle: 0x0000000000000240, id: 8540 (0x215c), stack base: 0x0000007f36c00000, stack limit: 0x0000007f36bb5000, stack current: 0x0000007f36bca270, base priority: 8, delta priority: 0, exception thread
6 OculusConfigUtil.exe 0x00007ff6df441a07 +-1
7 OculusConfigUtil.exe 0x00007ff6df441a07 +-1
8 OculusConfigUtil.exe 0x00007ff6df43499a +-1
9 OculusConfigUtil.exe 0x00007ff6df42702f +-1
10 OculusConfigUtil.exe 0x00007ff6df421701 +-1
11 OculusConfigUtil.exe 0x00007ff6df8d2186 +-1
12 OculusConfigUtil.exe 0x00007ff6df571a32 +-1
13 OculusConfigUtil.exe 0x00007ff6df4deb22 +-1
14 OculusConfigUtil.exe 0x00007ff6df4de3f1 +-1
15 OculusConfigUtil.exe 0x00007ff6df4dfc5f +-1
16 OculusConfigUtil.exe 0x00007ff6df4b5332 +-1
17 OculusConfigUtil.exe 0x00007ff6df56b705 +-1
18 OculusConfigUtil.exe 0x00007ff6df569746 +-1
19 OculusConfigUtil.exe 0x00007ff6df914298 +-1
20 OculusConfigUtil.exe 0x00007ff6df56d0de +-1
21 OculusConfigUtil.exe 0x00007ff6df5e6620 +-1
22 OculusConfigUtil.exe 0x00007ff6df5e44cb +-1
23 OculusConfigUtil.exe 0x00007ff6df56b705 +-1
24 OculusConfigUtil.exe 0x00007ff6df56ac18 +-1
25 OculusConfigUtil.exe 0x00007ff6df914298 +-1
26 OculusConfigUtil.exe 0x00007ff6dfba83c6 z_zlibVersion+511958
27 OculusConfigUtil.exe 0x00007ff6dfbaabf0 z_zlibVersion+522240
28 OculusConfigUtil.exe 0x00007ff6dfc65ad0 z_zlibVersion+1287904
29 OculusConfigUtil.exe 0x00007ff6dfa20b29 +-1
30 USER32.dll 0x00007ff8c52200dc DispatchMessageW+1676
31 USER32.dll 0x00007ff8c521fc07 DispatchMessageW+439
32 OculusConfigUtil.exe 0x00007ff6dfa2031b +-1
33 OculusConfigUtil.exe 0x00007ff6df832e54 +-1
34 OculusConfigUtil.exe 0x00007ff6df94f541 +-1
35 OculusConfigUtil.exe 0x00007ff6df42ecc3 +-1
36 OculusConfigUtil.exe 0x00007ff6df44be69 +-1
37 OculusConfigUtil.exe 0x00007ff6df482d79 +-1
38 OculusConfigUtil.exe 0x00007ff6dfe87905 z_zlibVersion+3523861
39 OculusConfigUtil.exe 0x00007ff6dfe18b18 z_zlibVersion+3069736
40 KERNEL32.DLL 0x00007ff8c5992d92 BaseThreadInitThunk+34
41 ntdll.dll 0x00007ff8c7929f64 RtlUserThreadStart+52
Thread handle: 0x0000000000000240, id: 7460 (0x1d24), stack base: 0x0000007f38dd0000, stack limit: 0x0000007f38db0000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
0 ntdll.dll 0x00007ff8c79b383a ZwDelayExecution+10
1 KERNELBASE.dll 0x00007ff8c4e43757 SleepEx+167
2 LibOVRRT64_0_7.dll 0x00007ff8a4ed625a ovr_GetEyePoses+114410
3 LibOVRRT64_0_7.dll 0x00007ff8a4ec90f0 ovr_GetEyePoses+60800
4 LibOVRRT64_0_7.dll 0x00007ff8a4ed65d8 ovr_GetEyePoses+115304
5 LibOVRRT64_0_7.dll 0x00007ff8a4ee0fbb ovr_GetEyePoses+158795
6 LibOVRRT64_0_7.dll 0x00007ff8a4ee1162 ovr_GetEyePoses+159218
7 KERNEL32.DLL 0x00007ff8c5992d92 BaseThreadInitThunk+34
8 ntdll.dll 0x00007ff8c7929f64 RtlUserThreadStart+52
Thread handle: 0x0000000000000240, id: 2248 (0x8c8), stack base: 0x0000007f38ed0000, stack limit: 0x0000007f38ecf000, stack current: 0x0000000000000000, base priority: 9, delta priority: 0
0 ntdll.dll 0x00007ff8c79b358a ZwRemoveIoCompletion+10
1 mswsock.dll 0x00007ff8c3b6f949 Tcpip4_WSHStringToAddress+265
2 KERNEL32.DLL 0x00007ff8c5992d92 BaseThreadInitThunk+34
3 ntdll.dll 0x00007ff8c7929f64 RtlUserThreadStart+52
Thread handle: 0x0000000000000240, id: 6732 (0x1a4c), stack base: 0x0000007f392d0000, stack limit: 0x0000007f392ce000, stack current: 0x0000000000000000, base priority: 15, delta priority: 0
0 ntdll.dll 0x00007ff8c79b3aaa NtWaitForMultipleObjects+10
1 WINMM.dll 0x00007ff8c28c28e0 PlaySoundW+4064
Thread handle: 0x0000000000000240, id: 7300 (0x1c84), stack base: 0x0000007f393d0000, stack limit: 0x0000007f393ce000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
0 ntdll.dll 0x00007ff8c79b505a ZwWaitForWorkViaWorkerFactory+10
1 ntdll.dll 0x00007ff8c79592d5 EtwEventRegister+741
Thread handle: 0x0000000000000240, id: 7480 (0x1d38), stack base: 0x0000007f394d0000, stack limit: 0x0000007f394ce000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 7668 (0x1df4), stack base: 0x0000007f3dd60000, stack limit: 0x0000007f3dd56000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 1472 (0x5c0), stack base: 0x0000007f3de60000, stack limit: 0x0000007f3de5f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8604 (0x219c), stack base: 0x0000007f3df60000, stack limit: 0x0000007f3df5f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8232 (0x2028), stack base: 0x0000007f3e060000, stack limit: 0x0000007f3e05f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 9364 (0x2494), stack base: 0x0000007f3e160000, stack limit: 0x0000007f3e15e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8824 (0x2278), stack base: 0x0000007f3e260000, stack limit: 0x0000007f3e25e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 3264 (0xcc0), stack base: 0x0000007f3e360000, stack limit: 0x0000007f3e35e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 5892 (0x1704), stack base: 0x0000007f3e460000, stack limit: 0x0000007f3e45f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 2516 (0x9d4), stack base: 0x0000007f3e560000, stack limit: 0x0000007f3e55f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 5228 (0x146c), stack base: 0x0000007f3e660000, stack limit: 0x0000007f3e656000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8048 (0x1f70), stack base: 0x0000007f3e760000, stack limit: 0x0000007f3e75f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 6608 (0x19d0), stack base: 0x0000007f3e860000, stack limit: 0x0000007f3e85f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 4924 (0x133c), stack base: 0x0000007f3e960000, stack limit: 0x0000007f3e95f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 4520 (0x11a8), stack base: 0x0000007f3ea60000, stack limit: 0x0000007f3ea5f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 4880 (0x1310), stack base: 0x0000007f3eb60000, stack limit: 0x0000007f3eb5e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 9096 (0x2388), stack base: 0x0000007f3ec60000, stack limit: 0x0000007f3ec5e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 4324 (0x10e4), stack base: 0x0000007f3ef00000, stack limit: 0x0000007f3eeff000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 10160 (0x27b0), stack base: 0x0000007f3f000000, stack limit: 0x0000007f3efff000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8900 (0x22c4), stack base: 0x0000007f3f100000, stack limit: 0x0000007f3f0f6000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 7680 (0x1e00), stack base: 0x0000007f3f200000, stack limit: 0x0000007f3f1ff000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 4384 (0x1120), stack base: 0x0000007f3f300000, stack limit: 0x0000007f3f2fe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 9520 (0x2530), stack base: 0x0000007f3f400000, stack limit: 0x0000007f3f3fe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 7268 (0x1c64), stack base: 0x0000007f3f500000, stack limit: 0x0000007f3f4ff000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8656 (0x21d0), stack base: 0x0000007f3f600000, stack limit: 0x0000007f3f5fe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 7936 (0x1f00), stack base: 0x0000007f3f700000, stack limit: 0x0000007f3f6fe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 9556 (0x2554), stack base: 0x0000007f3f800000, stack limit: 0x0000007f3f7f6000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8092 (0x1f9c), stack base: 0x0000007f3f900000, stack limit: 0x0000007f3f8fe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 9168 (0x23d0), stack base: 0x0000007f3fa00000, stack limit: 0x0000007f3f9ff000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 3172 (0xc64), stack base: 0x0000007f3fb00000, stack limit: 0x0000007f3faff000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 6312 (0x18a8), stack base: 0x0000007f3fc00000, stack limit: 0x0000007f3fbfe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 7824 (0x1e90), stack base: 0x0000007f3fd00000, stack limit: 0x0000007f3fcfe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 4068 (0xfe4), stack base: 0x0000007f3fe00000, stack limit: 0x0000007f3fdfe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 4452 (0x1164), stack base: 0x0000007f3ff00000, stack limit: 0x0000007f3fefe000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 6764 (0x1a6c), stack base: 0x0000007f40080000, stack limit: 0x0000007f40076000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 9292 (0x244c), stack base: 0x0000007f40180000, stack limit: 0x0000007f4017e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 1508 (0x5e4), stack base: 0x0000007f40280000, stack limit: 0x0000007f4027e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 5856 (0x16e0), stack base: 0x0000007f40380000, stack limit: 0x0000007f4037f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 5916 (0x171c), stack base: 0x0000007f40480000, stack limit: 0x0000007f4047f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8368 (0x20b0), stack base: 0x0000007f40580000, stack limit: 0x0000007f4057e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 740 (0x2e4), stack base: 0x0000007f40680000, stack limit: 0x0000007f4067e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 3024 (0xbd0), stack base: 0x0000007f40780000, stack limit: 0x0000007f4077e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 2292 (0x8f4), stack base: 0x0000007f40880000, stack limit: 0x0000007f4087f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 1272 (0x4f8), stack base: 0x0000007f40980000, stack limit: 0x0000007f40976000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 2652 (0xa5c), stack base: 0x0000007f41330000, stack limit: 0x0000007f4132f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 9372 (0x249c), stack base: 0x0000007f41430000, stack limit: 0x0000007f4142f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 8020 (0x1f54), stack base: 0x0000007f41530000, stack limit: 0x0000007f4152e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 580 (0x244), stack base: 0x0000007f41630000, stack limit: 0x0000007f4162f000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 7892 (0x1ed4), stack base: 0x0000007f41730000, stack limit: 0x0000007f4172e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 3080 (0xc08), stack base: 0x0000007f41830000, stack limit: 0x0000007f4182e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
Thread handle: 0x0000000000000240, id: 5056 (0x13c0), stack base: 0x0000007f41930000, stack limit: 0x0000007f4192e000, stack current: 0x0000000000000000, base priority: 8, delta priority: 0
1 KERNELBASE.dll 0x00007ff8c4e5913f WaitForMultipleObjectsEx+239
2 combase.dll 0x00007ff8c7402e97 CoRegisterInitializeSpy+999
3 combase.dll 0x00007ff8c7402d48 CoRegisterInitializeSpy+664
4 combase.dll 0x00007ff8c73bd933 RoGetActivationFactory+12579
5 combase.dll 0x00007ff8c74062bc CoFreeUnusedLibrariesEx+1420
6 KERNEL32.DLL 0x00007ff8c5992d92 BaseThreadInitThunk+34
7 ntdll.dll 0x00007ff8c7929f64 RtlUserThreadStart+52
Module list
Base Size Entrypoint Name Path
0x00007ff6df410000 0x000000000168c000 0x00007ff6dfe189bc "OculusConfigUtil.exe" "C:\Program Files (x86)\Oculus\Tools\OculusConfigUtil.exe"
0x00007ff8c7920000 0x00000000001c1000 0x0000000000000000 "ntdll.dll" "C:\WINDOWS\SYSTEM32\ntdll.dll"
0x00007ff8c5980000 0x00000000000ad000 0x00007ff8c5992e30 "KERNEL32.DLL" "C:\WINDOWS\system32\KERNEL32.DLL"
0x00007ff8c4e10000 0x00000000001dd000 0x00007ff8c4e1ba70 "KERNELBASE.dll" "C:\WINDOWS\system32\KERNELBASE.dll"
0x00007ff8c5210000 0x000000000014e000 0x00007ff8c5219d90 "USER32.dll" "C:\WINDOWS\system32\USER32.dll"
0x00007ff8c7680000 0x0000000000186000 0x00007ff8c76cd020 "GDI32.dll" "C:\WINDOWS\system32\GDI32.dll"
0x00007ff8c5a30000 0x00000000000a6000 0x00007ff8c5a461e0 "ADVAPI32.dll" "C:\WINDOWS\system32\ADVAPI32.dll"
0x00007ff8c54c0000 0x000000000009d000 0x00007ff8c54c78a0 "msvcrt.dll" "C:\WINDOWS\system32\msvcrt.dll"
0x00007ff8c72e0000 0x000000000005b000 0x00007ff8c72f7530 "sechost.dll" "C:\WINDOWS\system32\sechost.dll"
0x00007ff8c5ae0000 0x0000000000126000 0x00007ff8c5b4eb50 "RPCRT4.dll" "C:\WINDOWS\system32\RPCRT4.dll"
0x00007ff8c5d70000 0x0000000001522000 0x00007ff8c5ec77b0 "SHELL32.dll" "C:\WINDOWS\system32\SHELL32.dll"
0x00007ff8c4720000 0x0000000000629000 0x00007ff8c48dafb0 "windows.storage.dll" "C:\WINDOWS\system32\windows.storage.dll"
0x00007ff8c7340000 0x000000000027c000 0x00007ff8c7413700 "combase.dll" "C:\WINDOWS\system32\combase.dll"
0x00007ff8c5560000 0x0000000000051000 0x00007ff8c556ee30 "shlwapi.dll" "C:\WINDOWS\system32\shlwapi.dll"
0x00007ff8c4370000 0x000000000000f000 0x00007ff8c4373220 "kernel.appcore.dll" "C:\WINDOWS\system32\kernel.appcore.dll"
0x00007ff8c4d50000 0x00000000000b3000 0x00007ff8c4d91b20 "shcore.dll" "C:\WINDOWS\system32\shcore.dll"
0x00007ff8c4380000 0x000000000004a000 0x00007ff8c4383460 "powrprof.dll" "C:\WINDOWS\system32\powrprof.dll"
0x00007ff8c4350000 0x0000000000013000 0x00007ff8c4355130 "profapi.dll" "C:\WINDOWS\system32\profapi.dll"
0x00007ff8c5360000 0x0000000000141000 0x00007ff8c5384e60 "ole32.dll" "C:\WINDOWS\system32\ole32.dll"
0x00007ff8c75c0000 0x00000000000be000 0x00007ff8c75dafa0 "OLEAUT32.dll" "C:\WINDOWS\system32\OLEAUT32.dll"
0x00007ff8c45c0000 0x0000000000054000 0x00007ff8c45d84b0 "WINTRUST.dll" "C:\WINDOWS\system32\WINTRUST.dll"
0x00007ff8c43d0000 0x0000000000011000 0x00007ff8c43d5960 "MSASN1.dll" "C:\WINDOWS\system32\MSASN1.dll"
0x00007ff8c43f0000 0x00000000001c1000 0x00007ff8c444b120 "CRYPT32.dll" "C:\WINDOWS\system32\CRYPT32.dll"
0x00007ff8c72a0000 0x0000000000036000 0x00007ff8c72a1310 "IMM32.dll" "C:\WINDOWS\system32\IMM32.dll"
0x00007ff8c5c10000 0x000000000015c000 0x00007ff8c5c4e040 "MSCTF.dll" "C:\WINDOWS\system32\MSCTF.dll"
0x00007ff8c55d0000 0x0000000000069000 0x00007ff8c55e7870 "WS2_32.dll" "C:\WINDOWS\system32\WS2_32.dll"
0x00007ff8c7910000 0x0000000000008000 0x00007ff8c7911ea0 "NSI.dll" "C:\WINDOWS\system32\NSI.dll"
0x00007ff8a2ef0000 0x0000000000404000 0x00007ff8a327f360 "D3DCOMPILER_47.dll" "C:\Program Files (x86)\Oculus\Tools\D3DCOMPILER_47.dll"
0x00007ff8c1aa0000 0x000000000009c000 0x00007ff8c1abd890 "dxgi.dll" "C:\WINDOWS\SYSTEM32\dxgi.dll"
0x00007ff8b8600000 0x000000000000a000 0x00007ff8b8601330 "VERSION.dll" "C:\WINDOWS\SYSTEM32\VERSION.dll"
0x00007ff8c28c0000 0x0000000000023000 0x00007ff8c28c3680 "WINMM.dll" "C:\WINDOWS\SYSTEM32\WINMM.dll"
0x00007ff8bd2f0000 0x0000000000128000 0x00007ff8bd3ceb90 "OPENGL32.dll" "C:\WINDOWS\SYSTEM32\OPENGL32.dll"
0x00007ff8c2680000 0x000000000002c000 0x00007ff8c2688950 "WINMMBASE.dll" "C:\WINDOWS\SYSTEM32\WINMMBASE.dll"
0x00007ff8c46d0000 0x0000000000044000 0x00007ff8c46e2cb0 "cfgmgr32.dll" "C:\WINDOWS\system32\cfgmgr32.dll"
0x00007ff8bd280000 0x000000000002e000 0x00007ff8bd29e0e0 "GLU32.dll" "C:\WINDOWS\SYSTEM32\GLU32.dll"
0x00007ff8b7fc0000 0x00000000000f6000 0x00007ff8b7fcd800 "DDRAW.dll" "C:\WINDOWS\SYSTEM32\DDRAW.dll"
0x00007ff8c2cc0000 0x0000000000027000 0x00007ff8c2cc7270 "DEVOBJ.dll" "C:\WINDOWS\SYSTEM32\DEVOBJ.dll"
0x00007ff8bdc00000 0x0000000000008000 0x00007ff8bdc01e70 "DCIMAN32.dll" "C:\WINDOWS\SYSTEM32\DCIMAN32.dll"
0x00007ff8c3d30000 0x000000000000b000 0x00007ff8c3d31a50 "CRYPTBASE.DLL" "C:\WINDOWS\SYSTEM32\CRYPTBASE.DLL"
0x00007ff8c4170000 0x000000000006b000 0x00007ff8c41a5f50 "bcryptPrimitives.dll" "C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll"
0x00007ff8c1b40000 0x00000000002a3000 0x00007ff8c1bd3050 "d3d11.dll" "C:\WINDOWS\SYSTEM32\d3d11.dll"
0x00007ff8c2c20000 0x0000000000096000 0x00007ff8c2c439f0 "uxtheme.dll" "C:\WINDOWS\system32\uxtheme.dll"
0x00007ff8c1e00000 0x0000000000022000 0x00007ff8c1e03410 "dwmapi.dll" "C:\WINDOWS\system32\dwmapi.dll"
0x00007ff8a4ea0000 0x0000000000113000 0x00007ff8a4edfd74 "LibOVRRT64_0_7.dll" "C:\WINDOWS\SYSTEM32\LibOVRRT64_0_7.dll"
0x00007ff8c3b60000 0x000000000005d000 0x00007ff8c3b724f0 "mswsock.dll" "C:\WINDOWS\system32\mswsock.dll"
0x00007ff8b3bc0000 0x000000000018a000 0x00007ff8b3bcfac0 "DbgHelp.dll" "C:\WINDOWS\SYSTEM32\DbgHelp.dll"
0x00007ff8c3bc0000 0x0000000000017000 0x00007ff8c3bc77e0 "cryptsp.dll" "C:\WINDOWS\SYSTEM32\cryptsp.dll"
0x00007ff8c4280000 0x0000000000028000 0x00007ff8c42940c0 "bcrypt.dll" "C:\WINDOWS\SYSTEM32\bcrypt.dll"
0x00007ff8c3810000 0x0000000000033000 0x00007ff8c3828f10 "rsaenh.dll" "C:\WINDOWS\system32\rsaenh.dll"
0x00007ff8c5700000 0x00000000000a5000 0x00007ff8c5703340 "clbcatq.dll" "C:\WINDOWS\system32\clbcatq.dll"
0x00007ff8b09a0000 0x0000000000046000 0x00007ff8b09a4030 "dataexchange.dll" "C:\WINDOWS\system32\dataexchange.dll"
0x00007ff8b9360000 0x0000000000545000 0x00007ff8b9513e50 "d2d1.dll" "C:\WINDOWS\system32\d2d1.dll"
0x00007ff8c25a0000 0x00000000000d1000 0x00007ff8c25ccc50 "dcomp.dll" "C:\WINDOWS\system32\dcomp.dll"
0x00007ff8c2d10000 0x00000000000ee000 0x00007ff8c2d50960 "twinapi.appcore.dll" "C:\WINDOWS\system32\twinapi.appcore.dll"
0x00007ff8c3900000 0x000000000001f000 0x00007ff8c3905c50 "USERENV.dll" "C:\WINDOWS\system32\USERENV.dll"
0x00007ff8c0bb0000 0x0000000000d14000 0x00007ff8c0bb32d8 "igd10iumd64.dll" "C:\WINDOWS\SYSTEM32\igd10iumd64.dll"
0x00007ff8c3e00000 0x0000000000026000 0x00007ff8c3e0be40 "ncrypt.dll" "C:\WINDOWS\SYSTEM32\ncrypt.dll"
0x00007ff8c3dc0000 0x0000000000036000 0x00007ff8c3dc16b0 "NTASN1.dll" "C:\WINDOWS\SYSTEM32\NTASN1.dll"
0x00007ff8c00d0000 0x0000000000a02000 0x00007ff8c016b7e8 "igdusc64.dll" "C:\WINDOWS\SYSTEM32\igdusc64.dll"
0x00007ff8bfe50000 0x0000000000011000 0x00007ff8bfe52fe0 "wbemprox.dll" "C:\WINDOWS\system32\wbem\wbemprox.dll"
0x00007ff8bed90000 0x000000000007f000 0x00007ff8beda6670 "wbemcomn.dll" "C:\WINDOWS\SYSTEM32\wbemcomn.dll"
0x00007ff8be5a0000 0x0000000000014000 0x00007ff8be5a17e0 "wbemsvc.dll" "C:\WINDOWS\system32\wbem\wbemsvc.dll"
0x00007ff8be5c0000 0x00000000000f8000 0x00007ff8be5f47b0 "fastprox.dll" "C:\WINDOWS\system32\wbem\fastprox.dll"
0x00007ff8b3780000 0x000000000002f000 0x00007ff8b3781c80 "edputil.dll" "C:\WINDOWS\SYSTEM32\edputil.dll"
0x00007ff8beec0000 0x0000000000131000 0x00007ff8beeeb9d0 "wintypes.dll" "C:\WINDOWS\SYSTEM32\wintypes.dll"
0x00007ff8b8940000 0x0000000000376000 0x00007ff8b898d6a0 "iertutil.dll" "C:\WINDOWS\SYSTEM32\iertutil.dll"
0x00007ff8bb4d0000 0x0000000000039000 0x00007ff8bb4d3c80 "policymanager.dll" "C:\WINDOWS\SYSTEM32\policymanager.dll"
0x00007ff8bc6c0000 0x0000000000092000 0x00007ff8bc70a780 "msvcp110_win.dll" "C:\WINDOWS\SYSTEM32\msvcp110_win.dll"
0x00007ff8bee10000 0x0000000000036000 0x00007ff8bee1fa80 "XmlLite.dll" "C:\WINDOWS\SYSTEM32\XmlLite.dll"
0x00007ff8aa5d0000 0x0000000000025000 0x00007ff8aa5e9a80 "dbgcore.DLL" "C:\WINDOWS\SYSTEM32\dbgcore.DLL"
0x00007ff8c55c0000 0x0000000000008000 0x00007ff8c55c10c0 "psapi.dll" "C:\WINDOWS\system32\psapi.dll"
Process list
Disabled by report privacy settings
MiniDump: https://www.dropbox.com/s/o7twrt7qjsb97sh/Exception%20Minidump%20%282015-09-06%2020.05.56%29.mdmp?dl...
Not sure what else to do now..
michealv
Seems like we are both Shit out of luck.
CPU: Intel i7 4770k 3.8ghz (water-cooled) | GPU: G1 980ti 6gb | G.Skill Ripjaw's 16GB DDR3 1600mhz | 28" Samsung LED 4k monitor (60hz display port) )
cybereality
Level 15
I don't believe Intel GPUs will work. You need a dedicated card, like GTX 970.
Nickoplier
I find this amazingly disappointing that the Oculus Rift developers took this turn. It worked amazingly jittery free before with an older run time, but I guess Video Driver's had to come into the equation and the removal of an alternative that would work perfectly from extended displays.
Nickoplier
Update: The Oculus Configuration Utility now says that the Oculus Rift DK2 is Attached, but 'Event Viewer' is reporting deadlock everytime I try to open any Oculus Rift games.
10/11/15 22:41:59: Error: {ERR-027} [WatchDogObserver] Deadlock detected: NetServer
10/11/15 22:41:59: Error: [From Service] 10/11/15 22:41:59: {ERR-027} [WatchDogObserver] Deadlock detected: NetServer
10/11/15 22:41:58: Error: ---DEADLOCK STATE--- Thread handle: 0x0000000000000f30, id: 3188 (0xc74), stack base: 0x000000c43e2b0000, stack limit: 0x000000c43e290000 0 ntdll.dll 0x00007ffa7e343aaa NtWaitForMultipleObjects+10 1 KERNELBASE.dll 0x00007ffa7b5b913f WaitForMultipleObjectsEx+239 2 KERNELBASE.dll 0x00007ffa7b5b903e WaitForMultipleObjects+14 3 OVRServer_x64.exe 0x00007ff6487a1a6f +-1 4 OVRServer_x64.exe 0x00007ff6487a1e91 +-1 5 OVRServer_x64.exe 0x00007ff648897298 hid_write+671320 6 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 7 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 2644 (0xa54), stack base: 0x000000c440210000, stack limit: 0x000000c44020d000 0 ntdll.dll 0x00007ffa7e34353a ZwWaitForSingleObject+10 1 KERNELBASE.dll 0x00007ffa7b59415f WaitForSingleObjectEx+143 2 OVRServer_x64.exe 0x00007ff6488d3939 hid_write+918777 3 OVRServer_x64.exe 0x00007ff64889abe6 hid_write+685990 4 OVRServer_x64.exe 0x00007ff648894264 hid_write+658980 5 OVRServer_x64.exe 0x00007ff6487a222f +-1 6 OVRServer_x64.exe 0x00007ff6487a2e3c +-1 7 OVRServer_x64.exe 0x00007ff64879827a +-1 8 OVRServer_x64.exe 0x00007ff6487987d8 +-1 9 OVRServer_x64.exe 0x00007ff6488936cc hid_write+656012 10 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 11 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 12 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 13 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 2400 (0x960), stack base: 0x000000c440310000, stack limit: 0x000000c4402f0000 0 OVRServer_x64.exe 0x00007ff6487c72c3 +-1 1 OVRServer_x64.exe 0x00007ff6487c8094 +-1 2 OVRServer_x64.exe 0x00007ff6487c8545 +-1 3 OVRServer_x64.exe 0x00007ff6487cb295 +-1 4 OVRServer_x64.exe 0x00007ff6487ce1a8 +-1 5 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 6 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 7 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 8 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 2648 (0xa58), stack base: 0x000000c440410000, stack limit: 0x000000c4403f0000 0 ntdll.dll 0x00007ffa7e34502a ZwWaitForAlertByThreadId+10 1 ntdll.dll 0x00007ffa7e2e5d8a RtlReleasePath+1530 2 ntdll.dll 0x00007ffa7e2e5c8a RtlReleasePath+1274 3 ntdll.dll 0x00007ffa7e2e5b2f RtlReleasePath+927 4 ntdll.dll 0x00007ffa7e2e4fe9 RtlEnterCriticalSection+297 5 ntdll.dll 0x00007ffa7e2e4f00 RtlEnterCriticalSection+64 6 OVRServer_x64.exe 0x00007ff6487b7c95 +-1 7 OVRServer_x64.exe 0x00007ff6487b76eb +-1 8 OVRServer_x64.exe 0x00007ff6487d9b74 +-1 9 OVRServer_x64.exe 0x00007ff6487f93ad hid_write+24429 10 OVRServer_x64.exe 0x00007ff6488263f8 hid_write+208824 11 OVRServer_x64.exe 0x00007ff6487ce1a8 +-1 12 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 13 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 14 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 15 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 4716 (0x126c), stack base: 0x000000c4405f0000, stack limit: 0x000000c4405d0000 0 USER32.dll 0x00007ffa7c7afcba InvalidateRect+42 1 USER32.dll 0x00007ffa7c79f8e5 GetMessageW+37 2 OVRServer_x64.exe 0x00007ff64881ab54 hid_write+161556 3 OVRServer_x64.exe 0x00007ff6487ce1a8 +-1 4 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 5 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 6 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 7 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 4488 (0x1188), stack base: 0x000000c4407c0000, stack limit: 0x000000c4407b8000 0 ntdll.dll 0x00007ffa7e34502a ZwWaitForAlertByThreadId+10 1 ntdll.dll 0x00007ffa7e2e5d8a RtlReleasePath+1530 2 ntdll.dll 0x00007ffa7e2e5c8a RtlReleasePath+1274 3 ntdll.dll 0x00007ffa7e2e5b2f RtlReleasePath+927 4 ntdll.dll 0x00007ffa7e2e4fe9 RtlEnterCriticalSection+297 5 ntdll.dll 0x00007ffa7e2e4f00 RtlEnterCriticalSection+64 6 OVRServer_x64.exe 0x00007ff6487fab56 hid_write+30486 7 OVRServer_x64.exe 0x00007ff6487acdc7 +-1 8 OVRServer_x64.exe 0x00007ff6487e8e00 +-1 9 OVRServer_x64.exe 0x00007ff6487ebf0e +-1 10 OVRServer_x64.exe 0x00007ff6488795f1 hid_write+549297 11 OVRServer_x64.exe 0x00007ff64887637e hid_write+536382 12 OVRServer_x64.exe 0x00007ff648873f36 hid_write+527094 13 OVRServer_x64.exe 0x00007ff64882de6d hid_write+240173 14 OVRServer_x64.exe 0x00007ff64882d7f2 hid_write+238514 15 OVRServer_x64.exe 0x00007ff6487db080 +-1 16 OVRServer_x64.exe 0x00007ff6487ce1a8 +-1 17 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 18 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 19 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 20 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 1912 (0x778), stack base: 0x000000c4409c0000, stack limit: 0x000000c4409a0000 0 ntdll.dll 0x00007ffa7e34383a ZwDelayExecution+10 1 KERNELBASE.dll 0x00007ffa7b5a3757 SleepEx+167 2 OVRServer_x64.exe 0x00007ff6487cde4a +-1 3 OVRServer_x64.exe 0x00007ff6487b0d0a +-1 4 OVRServer_x64.exe 0x00007ff6487ad53b +-1 5 OVRServer_x64.exe 0x00007ff6487ce1a8 +-1 6 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 7 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 8 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 9 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 140 (0x8c), stack base: 0x000000c440ac0000, stack limit: 0x000000c440aa0000 0 ntdll.dll 0x00007ffa7e343aaa NtWaitForMultipleObjects+10 1 KERNELBASE.dll 0x00007ffa7b5b913f WaitForMultipleObjectsEx+239 2 KERNELBASE.dll 0x00007ffa7b5b903e WaitForMultipleObjects+14 3 OVRServer_x64.exe 0x00007ff648856196 hid_write+404822 4 OVRServer_x64.exe 0x00007ff648822f95 hid_write+195413 5 OVRServer_x64.exe 0x00007ff648820229 hid_write+183785 6 OVRServer_x64.exe 0x00007ff6487fa493 hid_write+28755 7 OVRServer_x64.exe 0x00007ff6487fa1d1 hid_write+28049 8 OVRServer_x64.exe 0x00007ff6487bc2ee +-1 9 OVRServer_x64.exe 0x00007ff6487bc110 +-1 10 OVRServer_x64.exe 0x00007ff6487b8719 +-1 11 OVRServer_x64.exe 0x00007ff6487d8099 +-1 12 OVRServer_x64.exe 0x00007ff6488104a1 hid_write+118881 13 OVRServer_x64.exe 0x00007ff64880fbd1 hid_write+116625 14 OVRServer_x64.exe 0x00007ff64885295b hid_write+390427 15 OVRServer_x64.exe 0x00007ff6488522cf hid_write+388751 16 OVRServer_x64.exe 0x00007ff64880ec84 hid_write+112708 17 OVRServer_x64.exe 0x00007ff6487c3be3 +-1 18 OVRServer_x64.exe 0x00007ff6487ce1a8 +-1 19 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 20 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 21 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 22 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 2840 (0xb18), stack base: 0x000000c440bc0000, stack limit: 0x000000c440ba0000 0 ntdll.dll 0x00007ffa7e34353a ZwWaitForSingleObject+10 1 KERNELBASE.dll 0x00007ffa7b59415f WaitForSingleObjectEx+143 2 OVRServer_x64.exe 0x00007ff6487c399c +-1 3 OVRServer_x64.exe 0x00007ff6487ce1a8 +-1 4 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 5 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 6 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 7 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 1636 (0x664), stack base: 0x000000c440cc0000, stack limit: 0x000000c440cbf000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 5688 (0x1638), stack base: 0x000000c445060000, stack limit: 0x000000c44505e000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 8988 (0x231c), stack base: 0x000000c445160000, stack limit: 0x000000c445153000 0 ntdll.dll 0x00007ffa7e343aaa NtWaitForMultipleObjects+10 1 KERNELBASE.dll 0x00007ffa7b5b913f WaitForMultipleObjectsEx+239 2 KERNELBASE.dll 0x00007ffa7b5b903e WaitForMultipleObjects+14 3 KERNEL32.DLL 0x00007ffa7bd7155c BasepReportFault+1356 4 KERNEL32.DLL 0x00007ffa7bd71088 BasepReportFault+120 5 KERNELBASE.dll 0x00007ffa7b5e037d UnhandledExceptionFilter+509 6 ntdll.dll 0x00007ffa7e348992 memset+2130 7 ntdll.dll 0x00007ffa7e333f66 _C_specific_handler+150 8 ntdll.dll 0x00007ffa7e34633d _chkstk+253 9 ntdll.dll 0x00007ffa7e2c3c00 RtlWalkFrameChain+5472 10 ntdll.dll 0x00007ffa7e34544a KiUserExceptionDispatcher+58 11 OVRServer_x64.exe 0x00007ff648889af1 hid_write+616113 12 OVRServer_x64.exe 0x00007ff648823e9d hid_write+199261 13 OVRServer_x64.exe 0x00007ff6488603e9 hid_write+446377 14 OVRServer_x64.exe 0x00007ff648860efa hid_write+449210 15 OVRServer_x64.exe 0x00007ff64885f7e7 hid_write+443303 16 OVRServer_x64.exe 0x00007ff6488936cc hid_write+656012 17 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 18 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 19 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 20 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 9008 (0x2330), stack base: 0x000000c445260000, stack limit: 0x000000c44525e000 0 ntdll.dll 0x00007ffa7e34353a ZwWaitForSingleObject+10 1 KERNELBASE.dll 0x00007ffa7b59415f WaitForSingleObjectEx+143 2 OVRServer_x64.exe 0x00007ff64885f395 hid_write+442197 3 OVRServer_x64.exe 0x00007ff64885f80c hid_write+443340 4 OVRServer_x64.exe 0x00007ff6488936cc hid_write+656012 5 OVRServer_x64.exe 0x00007ff6488a1d2f hid_write+714991 6 OVRServer_x64.exe 0x00007ff6488a1ed6 hid_write+715414 7 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 8 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 9012 (0x2334), stack base: 0x000000c445390000, stack limit: 0x000000c445386000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 8996 (0x2324), stack base: 0x000000c445490000, stack limit: 0x000000c445486000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 8984 (0x2318), stack base: 0x000000c445590000, stack limit: 0x000000c445586000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 8992 (0x2320), stack base: 0x000000c445690000, stack limit: 0x000000c445686000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 9000 (0x2328), stack base: 0x000000c4464f0000, stack limit: 0x000000c4464ef000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 8292 (0x2064), stack base: 0x000000c4465f0000, stack limit: 0x000000c4465ef000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 9044 (0x2354), stack base: 0x000000c4466f0000, stack limit: 0x000000c4466ef000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 9048 (0x2358), stack base: 0x000000c4467f0000, stack limit: 0x000000c4467ef000 0 ntdll.dll 0x00007ffa7e34505a ZwWaitForWorkViaWorkerFactory+10 1 ntdll.dll 0x00007ffa7e2e92d5 EtwEventRegister+741 2 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 3 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Thread handle: 0x0000000000000f30, id: 8196 (0x2004), stack base: 0x000000c446910000, stack limit: 0x000000c44690e000 0 ntdll.dll 0x00007ffa7e343aaa NtWaitForMultipleObjects+10 1 KERNELBASE.dll 0x00007ffa7b5b913f WaitForMultipleObjectsEx+239 2 combase.dll 0x00007ffa7bb92e97 CoRegisterInitializeSpy+999 3 combase.dll 0x00007ffa7bb92d48 CoRegisterInitializeSpy+664 4 combase.dll 0x00007ffa7bb4d933 RoGetActivationFactory+12579 5 combase.dll 0x00007ffa7bb962bc CoFreeUnusedLibrariesEx+1420 6 KERNEL32.DLL 0x00007ffa7bd62d92 BaseThreadInitThunk+34 7 ntdll.dll 0x00007ffa7e2b9f64 RtlUserThreadStart+52 Base: 0x7ff648730000 Size: 0x3dd000 Name: 'OVRServer_x64.exe' Path: 'C:\Program Files (x86)\Oculus\Service\OVRServer_x64.exe' Base: 0x7ffa7e2b0000 Size: 0x1c1000 Name: 'ntdll.dll' Path: 'C:\WINDOWS\SYSTEM32\ntdll.dll' Base: 0x7ffa7bd50000 Size: 0xad000 Name: 'KERNEL32.DLL' Path: 'C:\WINDOWS\system32\KERNEL32.DLL' Base: 0x7ffa7b570000 Size: 0x1dd000 Name: 'KERNELBASE.dll' Path: 'C:\WINDOWS\system32\KERNELBASE.dll' Base: 0x7ffa7c780000 Size: 0x14e000 Name: 'USER32.dll' Path: 'C:\WINDOWS\system32\USER32.dll' Base: 0x7ffa7c5e0000 Size: 0x186000 Name: 'GDI32.dll' Path: 'C:\WINDOWS\system32\GDI32.dll' Base: 0x7ffa7e1a0000 Size: 0xa6000 Name: 'ADVAPI32.dll' Path: 'C:\WINDOWS\system32\ADVAPI32.dll' Base: 0x7ffa7c1c0000 Size: 0x9d000 Name: 'msvcrt.dll' Path: 'C:\WINDOWS\system32\msvcrt.dll' Base: 0x7ffa7ba70000 Size: 0x5b000 Name: 'sechost.dll' Path: 'C:\WINDOWS\system32\sechost.dll' Base: 0x7ffa7bfc0000 Size: 0x126000 Name: 'RPCRT4.dll' Path: 'C:\WINDOWS\system32\RPCRT4.dll' Base: 0x7ffa7cb20000 Size: 0x1522000 Name: 'SHELL32.dll' Path: 'C:\WINDOWS\system32\SHELL32.dll' Base: 0x7ffa7ad80000 Size: 0x628000 Name: 'windows.storage.dll' Path: 'C:\WINDOWS\system32\windows.storage.dll' Base: 0x7ffa7bad0000 Size: 0x27c000 Name: 'combase.dll' Path: 'C:\WINDOWS\system32\combase.dll' Base: 0x7ffa7be00000 Size: 0x51000 Name: 'shlwapi.dll' Path: 'C:\WINDOWS\system32\shlwapi.dll' Base: 0x7ffa7ad70000 Size: 0xf000 Name: 'kernel.appcore.dll' Path: 'C:\WINDOWS\system32\kernel.appcore.dll' Base: 0x7ffa7b3b0000 Size: 0xb3000 Name: 'shcore.dll' Path: 'C:\WINDOWS\system32\shcore.dll' Base: 0x7ffa7ace0000 Size: 0x4a000 Name: 'powrprof.dll' Path: 'C:\WINDOWS\system32\powrprof.dll' Base: 0x7ffa7ad30000 Size: 0x13000 Name: 'profapi.dll' Path: 'C:\WINDOWS\system32\profapi.dll' Base: 0x7ffa7be60000 Size: 0x141000 Name: 'ole32.dll' Path: 'C:\WINDOWS\system32\ole32.dll' Base: 0x7ffa7e050000 Size: 0xbe000 Name: 'OLEAUT32.dll' Path: 'C:\WINDOWS\system32\OLEAUT32.dll' Base: 0x7ffa7c260000 Size: 0x1c5000 Name: 'SETUPAPI.dll' Path: 'C:\WINDOWS\system32\SETUPAPI.dll' Base: 0x7ffa7b520000 Size: 0x44000 Name: 'CFGMGR32.dll' Path: 'C:\WINDOWS\system32\CFGMGR32.dll' Base: 0x7ffa7c150000 Size: 0x69000 Name: 'WS2_32.dll' Path: 'C:\WINDOWS\system32\WS2_32.dll' Base: 0x7ffa7bfb0000 Size: 0x8000 Name: 'NSI.dll' Path: 'C:\WINDOWS\system32\NSI.dll' Base: 0x7ffa761c0000 Size: 0x38000 Name: 'IPHLPAPI.DLL' Path: 'C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL' Base: 0x7ffa784d0000 Size: 0x9c000 Name: 'dxgi.dll' Path: 'C:\WINDOWS\SYSTEM32\dxgi.dll' Base: 0x7ffa79c30000 Size: 0xf8000 Name: 'tdh.dll' Path: 'C:\WINDOWS\SYSTEM32\tdh.dll' Base: 0x7ffa713e0000 Size: 0xa000 Name: 'VERSION.dll' Path: 'C:\WINDOWS\SYSTEM32\VERSION.dll' Base: 0x7ffa79070000 Size: 0x23000 Name: 'WINMM.dll' Path: 'C:\WINDOWS\SYSTEM32\WINMM.dll' Base: 0x7ffa6b210000 Size: 0x18a000 Name: 'dbghelp.dll' Path: 'C:\WINDOWS\SYSTEM32\dbghelp.dll' Base: 0x7ffa78bd0000 Size: 0x13000 Name: 'WTSAPI32.dll' Path: 'C:\WINDOWS\SYSTEM32\WTSAPI32.dll' Base: 0x7ffa79d30000 Size: 0xc000 Name: 'HID.DLL' Path: 'C:\WINDOWS\SYSTEM32\HID.DLL' Base: 0x7ffa78570000 Size: 0x2a3000 Name: 'd3d11.dll' Path: 'C:\WINDOWS\SYSTEM32\d3d11.dll' Base: 0x7ffa75f60000 Size: 0xb000 Name: 'WINNSI.DLL' Path: 'C:\WINDOWS\SYSTEM32\WINNSI.DLL' Base: 0x7ffa78f30000 Size: 0x2c000 Name: 'WINMMBASE.dll' Path: 'C:\WINDOWS\SYSTEM32\WINMMBASE.dll' Base: 0x7ffa79650000 Size: 0x27000 Name: 'DEVOBJ.dll' Path: 'C:\WINDOWS\SYSTEM32\DEVOBJ.dll' Base: 0x7ffa7cae0000 Size: 0x36000 Name: 'IMM32.DLL' Path: 'C:\WINDOWS\system32\IMM32.DLL' Base: 0x7ffa7c980000 Size: 0x15c000 Name: 'MSCTF.dll' Path: 'C:\WINDOWS\system32\MSCTF.dll' Base: 0x7ffa7aaa0000 Size: 0x58000 Name: 'WINSTA.dll' Path: 'C:\WINDOWS\SYSTEM32\WINSTA.dll' Base: 0x7ffa74a20000 Size: 0x1a000 Name: 'dhcpcsvc.DLL' Path: 'C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL' Base: 0x7ffa795b0000 Size: 0x96000 Name: 'uxtheme.dll' Path: 'C:\WINDOWS\system32\uxtheme.dll' Base: 0x7ffa7a4f0000 Size: 0x5d000 Name: 'mswsock.dll' Path: 'C:\WINDOWS\system32\mswsock.dll' Base: 0x7ffa78820000 Size: 0x22000 Name: 'dwmapi.dll' Path: 'C:\WINDOWS\system32\dwmapi.dll' Base: 0x7ffa7b750000 Size: 0x54000 Name: 'WINTRUST.dll' Path: 'C:\WINDOWS\system32\WINTRUST.dll' Base: 0x7ffa7ad50000 Size: 0x11000 Name: 'MSASN1.dll' Path: 'C:\WINDOWS\system32\MSASN1.dll' Base: 0x7ffa7b7b0000 Size: 0x1c1000 Name: 'CRYPT32.dll' Path: 'C:\WINDOWS\system32\CRYPT32.dll' Base: 0x7ffa7ac10000 Size: 0x28000 Name: 'bcrypt.dll' Path: 'C:\WINDOWS\SYSTEM32\bcrypt.dll' Base: 0x7ffa776b0000 Size: 0xd14000 Name: 'igd10iumd64.dll' Path: 'C:\WINDOWS\SYSTEM32\igd10iumd64.dll' Base: 0x7ffa7a790000 Size: 0x26000 Name: 'ncrypt.dll' Path: 'C:\WINDOWS\SYSTEM32\ncrypt.dll' Base: 0x7ffa7a750000 Size: 0x36000 Name: 'NTASN1.dll' Path: 'C:\WINDOWS\SYSTEM32\NTASN1.dll' Base: 0x7ffa76b30000 Size: 0xa02000 Name: 'igdusc64.dll' Path: 'C:\WINDOWS\SYSTEM32\igdusc64.dll' Base: 0x7ffa5f3c0000 Size: 0x25000 Name: 'dbgcore.DLL' Path: 'C:\WINDOWS\SYSTEM32\dbgcore.DLL' ---END OF DEADLOCK STATE---
dxdiag
