My Oculus Go is stuck on the USB update mode screen when powered on. I can volume up and down to select the options with the power buttons but it goes back here.
Via oculus support I've fully drained the battery then restarted with no success. Via youtube I've opened the device and disconnected the battery overnight with no success. Store replacement unavailable so I come to you with fingers crossed...any suggestions?
