Display port to HDMI adapter?
JeekoCZ
Hey, I was wondering if I could use a adapter since my GPU doesn't have a Displayport and I really don't want to have to wait until I get a new GPU.
This is the adapter I found: https://amzn.to/2JCH09W
22 REPLIES 22
Anonymous
Not applicable
No, Oculus said that HDMI adapters won't work.
Suurfer
Will DP > thunderbolt 3 work? I've heard rumors but I'm not entirely sure
Anonymous
Not applicable
Anonymous
Not applicable
Not possible.  HDMI can't handle the bandwidth
TheTarantula
Not true. HDMI 2.0 is perfectly capable of running 2560x1440@144Hz, otherwise the WMR headsets wouldn't work, and they use the same resolution or higher.
Anonymous
Not applicable
The HDMI 2.0 spec does have the bandwidth, the issue is that the adapters do not. At least that is the story.
Anonymous
Not applicable
OFF-TOPIC but do USB C Adapters work?
Anonymous
Not applicable
For laptops maybe, see the link I posted above.
TheTarantula
That's correct. I've encountered some exotic things out there like this:
https://www.siig.com/hdmi-2-0-to-displayport-1-2-converter-4kx2k-60hz.html
But it doesn't have a wide enough range of settings to do the job. And I'm not spending $200.00 to test it or the other exotic adapters that work similarly.
