01-18-2022 06:11 AM
Hello,
I have a small problem, I got myself an oculus quest2 and at the same time half life alyxs.
The game runs very well in Link (cable)
But by space problem, it is difficult to play in the room where my pc is.
So I use the airlink in my living room next to my box (livebox 5)
But headphone freezes (the sound bug and the image becomes fixed or jerky with up to the last field of vision loaded, otherwise around me it’s black) happen randomly (to about 5-10 min) which is quite disturbing.
Then the game returns to normal after a few seconds.
Ma cg is a 2070 super
My pc is connected via cpl to my box : https://www.amazon.fr/TP-Link-Mbps-Ethernet-Prise-Int%C3%A9gr%C3%A9e/dp/B00BUL8762/ref=asc_df_B00BUL...? tag=googshopfr-21&linkCode=df0&hvadid=48672744446&hvpos=&hvnetw=g&hvrand=16521864896338037849&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9055938&hvtargid=pla-79019699366&psc=1
My solution is so I move my pc to play.
Does anyone have a solution?
Thank you in advance
01-18-2022 08:00 AM
i have similar problem just that it does that whenever i use air link
01-18-2022 09:02 AM
Well don't use a power line adapter. Power line adapters are more for just to transmit data, its not getting a clean enough signal. Your inducing some latency into your setup.
01-18-2022 09:13 AM
It's also possible the headset is switching from 5GHz to 2.4GHz wifi. Do you have separate SSIDs for both frequencies? But yes, power line adapters are the connectivity of last resort and to be avoided if at all possible.
01-18-2022 12:04 PM
me too is the whole problem
01-18-2022 12:06 PM
Unfortunately this is the only possible solution because I can’t pull the cables
01-18-2022 12:09 PM
Okay, I’ll check that out, but I wonder if I took a good-quality Cpl, would that work?
