Guarding stopping
Brysonbest
Honored Guest
Brysonbest
Honored Guest
When i turnnirnon its only say, .com.oculs.keeps stopping
Hey there, Brysonbest! We would recommend pressing the power and volume down at the same time for about 30 seconds. Once the boot menu loads go to "exit and boot" and reboot the headset. If the issue continues, please reach out to our Support Team and we would be happy to look into this with you. It's our goal to have you back in peak gaming status as soon as possible!
