05-30-2018 10:27 PM
Enabling Mods:
- First, launch Skyrim VR and make sure it runs properly. Once confirmed, quit.
- Now on your PC navigate to:
Documents>My Games>Skyrim VR
and open theSkyrimPrefs.ini
document.- Add the heading
[Launcher]
at the bottom. Then, right under it, add the line:bEnableFileSelection=1
then save.
Nexus Mod Manager
- If you haven’t already, we highly recommend that you download and install the Nexus Mod Manager (NMM) to organize and keep track of all your mods.
- Now, run NMM (administration mode may be required). Once it opens, cancel the auto search (“Stop Searching” button) at the bottom right of the screen.
- Next, click the “…” button right below where it says Skyrim Special Edition.
- Select the folder:
*(steam installation path)*\Steam\steamapps\common\SkyrimVR\
- Click the little check mark above and ignore the warning that it couldn’t find the .exe.
Install mods
- Once you’ve selected the mods you want to install and downloaded them, you need to navigate to …
appdata\local\Skyrim Special Edition
and copy theplugins.txt
to your clipboard.- Now, navigate to
appdata\local\Skyrim VR
and paste the plugins.txt document into this folder.- Finally just close NMM and start adventuring!
Ok so I think I'm good up until Installing the mods... I don't have any "appdata" to navigate to. I have done a search on my drives and it's just not there. I realize the "appdata" is only part of the path, I just don't have any appdata subfolders.
So what am I doing wrong?
Thanks in advance!
05-30-2018 10:37 PM
05-30-2018 10:48 PM
05-30-2018 11:34 PM
05-31-2018 10:57 AM
05-31-2018 12:04 PM
