09-04-2022 11:46 AM
Hi
Workrooms works fine, but when i try to conenct to my PC using the Meta Quest Remote Desktop (v 1.6.0.15.257) the following happens:
- Desktop PC is found in Quest
- My Quest shows as Yellow in MQRD
- When i try to connect, Quest shows black window with progress icon, Quest goes green dot in MQRD and i get a yellow border around the monitor.
- Yellow border goes off and comes back on, before then going off completely
- Shortly afterwards i get the 'Remote Desktop Disconnected' message in Quest.
Please can you help.
09-07-2022 11:03 AM
Hiya Boothbed! We see you're having issues with the device to PC connection and we know how frustrating it can be. If you haven't already tried it, you could try uninstalling and installing the PC app. If that doesn't put things right, you will then want to submit a support ticket and gather logs. That way you get one on one support and attention. Instructions on how to gather logs are linked here and the link to support is here : https://metaque.st/Support. We appreciate you bringing this to our attention and hope you have a great day.
10-13-2022 02:06 AM - edited 10-13-2022 02:06 AM
Were you able to resolve this issue? I'm having the same problem on my side.
Tried reinstalling the PC app without success.
12-17-2022 07:12 AM
Any solution?
12-30-2022 08:46 AM
I've the same trouble.
Help
12-30-2022 09:19 AM
Hey there, @MrBiz! We definitely understand your concern with this error you're running into with remote desktop, and we'll love to help out! Please reach out to us via our Support Page so that we can take a closer look at the issue and see what we can learn, we'll do everything we can to help out!
