How many Quest can be attach to the same account?
Mauricio007
RoastPork
Meta Quest Support
Meta Quest Support
As I recall, theoretically, as many as you'd like. Multiple Quest 2s activated with the same account can't play online games at the same time, though. And if you have a game that works with Cloud Backup, then each device's save will be overwritten with the latest save. Hope that helps!
Now you're playing with power...SUPER power!
